CloserNet went very nicely, but we want to debug some of the zero payment nodes and data distribution questions it brought up.
As such we’ve got some extra logs on the go, as well as set up the client to choose nodes at random (from close nodes), rather than the cheapest. This should help confirm if we have in a client-side storage choice issue (or indeed price setting issue as our testing has shown) or something else is going on here.
We’ve ask node users to try and keep a good amount of logs too in case we need to try and debug a certain store effort, eg.
It will also be useful if RecordRejected (any other rejection reason except record rejected due to payment not to self) error were collected and reported if node users spot such activity
A note for testers:
Just to highlight for folk (as the question has cropped up in other threads), encryption of files is a client side endeavor, and right now there it s lower limit on what can be encrypted. So small file are not yet encrypted as things stand.
This also means that the DataMaps which are used to know where all the self-encrypted chunks of a file live are may not be encrypted. And these are currently stored on the network by default. (We’ll probably be moving these to be disk-only by default so the only things put to the network would be self-encrypted.)
And finally, registers are currently not encrypted at all. We’re looking at ways to improve UX and allow for encryption there too.
A wee ubuntu iso for verification:
safe --peer /ip4/178.62.3.215/tcp/45315/p2p/12D3KooWHRWEb5XQZU1cksTGxsvzJi22zUTjfhemRNiMHLL88868 files download ubuntu-18.04.6-desktop-amd64.iso f2fe721b1f3f7538de3d6003107a6db799e2f07ac0a0981aa8eae8ae3922cd8e
Network Details
Node version: 0.100.22
Client version: 0.86.76
Faucet url: 138.68.138.2:8000
We have 101 droplets running a total of 2001 nodes. One droplet has 2vcpu and 4GB of memory.
Quickstart
safeup client --version 0.86.76
safeup node --version 0.100.22
Run a Node
Linux/macOS:
safenode
Windows:
safenode
Linux/macOS:
safe wallet get-faucet 138.68.138.2:8000
Windows:
To do this with non-default batch-sizes (along with SAFE_PEERS set as above):
safe files upload --batch-size 40 <directory-path>
40 being the integer value you want to set
Further Information
Obtaining Binaries
Installing Safeup
Installing Binaries
safeup client --version 0.86.76 # get a specific version
safeup node --version 0.100.22 # get a specific version
Running a Node
# Linux/macOS
safenode
# Windows
safenode
This will output all the logs to the filesystem, with the location of logs being platform specific:
# Linux
# macOS
# Windows
# Linux/macOS
# Windows
Connecting as a Client
Using the Client
safe files download
# Linux
# macOS
# Windows
safe file download [directory/filename] [NetworkAddress]
Troubleshooting
Cleanup
# Linux
rm -rf ~/.local/share/safe
# macOS
# Windows
