Is it really a “new” coin if it has the same address as an “old” coin? A coin and an address have 1:1 correspondence. Given that property it’s the same coin placed back into circulation, since it has the same “name” or id.
It is new because the “new” coin is not being used for anything linked to by the spending of that coin. I.E. its not a coin that is paid to PUT then directly used to pay those farmers that retrieve the data that the coin paid for the PUTing of.
The only relation to the address is that address space is use to limit the total number of coins. They could have an 128bit address space and some method of ensuring only 2^32 coins can exist. And obviously some method of incorporating scarcity would be needed to.
The network used/spent that coin to purchase a GET or GETs from a farmer.
NO. The GETs rewarded are not on those chunks that were PUT by the spending of the coin at that address. Its a conceptual thing really and the reuse of an address is a technical method of limiting coins to 2^32 (and see the edit I wrote above)
Yes, I understand the process fully. My comment didn’t say that a client spent the coin for some PUTs which the network handed off to a farmer “hand to mouth”. I was pointing out that from the network’s perspective it spends its coin(s) on GETs as needed. So your “new” coin is being used for something linked to the spending of that coin, ie. spending by the network instead of a client. And if that coin has the same ID as a coin that was previously spent by a client for a PUT at some time in the past, then your definition above proves my point that it is not really a “new” coin, but the “same” coin.
From this point of view, “new” coins would only be those coins distributed to MAID holders at launch to seed the network economics, or those instantiated the very first time an address is used by the network to reward a farmer. These are minor definition/semantic details, but I think it’s important to debate, just like the misuse of the term “burn”.
EDIT: Not sure if any of this is relevant if Fraser’s alternative method is used.
Its how you define “new”
New is one of those words like perfect. You can turn arguments into anything almost.
The coin is new for the purposes of the algorithm.
As I said the algorithm could use a 128 bit address space with a mechanism to both limit number of coins to 2^32 and to incorporate the scarcity element. The algorithm still works the same and for the span of human life time no address is reused.
So I disagree with even your unintended use of the word “new” for the purposes of the network workings.
On the other hand its like saying in a program language where you have a “New Object” statement. Now for the purpose of the program the object is new, but in fact it has reused memory that was previously used for something else and that could even have been for the same object in a previous run of the program. So in SAFE it sees each coin created as “New” in the true sense, but for technical reasons like the program example the coin resides at the same address as a coin that was destroyed. Now this is made more clear by my example above where a 128 address space could have been used but limit # coins to 2^32
tl;dr And of course this is starting to sound like splitting hairs over termology
Misrepresenting what I said is another form of personal attack. But whatever, I will go straight to the cold hard facts:
For this calculation I will use the approximated total supply of 4.3 billion listed in white paper:
“It is anticipated that 4.3 billion coins will be produced during the life of the network”
4.3 billion / 20 years is 215 million coins / year. Current supply is 450 million. What’s
450 + 215 million in percent inflation? 47.7%.
I did some more digging and while the safecoin whitepaper does not mention emission rate, the old paper from 2014 does mention something of interest:
“Unlike gold, which only increases at circa 1.5% per annum, the quantity of safecoin will initially burgeon. This is akin to the California gold rush, where the quantity of gold grew quickly with enthusiastic miners. In safecoin this is mirrored by the network building to the stage where it is protecting all of the world’s data. During that time the mining frequency will be exponentially decreasing.”
“Burgeon” for those unfamiliar means “begin to grow or increase rapidly; flourish.”
It’s established that the coins are to be mostly distributed by the 20 year mark, but let me quote from the paper:
With the proposed mining procedure (and assumptions) it is estimated that half the total volume will issued during the first 5 years, with 95% issued after 10 years
Now sadly this is even worse than I thought. I can do the math for you again:
(4.3 * 0.95) / 10 is 408 million per year on average. Note that current supply is 450 million, and we will be getting 408 million new coins a year on average for 10 years after launch.
There’s only estimates in the paper, however it’s clear to me that we are going to see the most heavy inflation in early stages, as this graph confirms:
An estimate is also made that shows this:
While 2% coin supply is only 86 million coins. 19% inflation is still pretty steep. But it gets worse, much worse:
To reward investors and developers involved during the early stages of this project, it is proposed that 30% of all safecoins will be injected into the network on day 1. Up to 10% will be available for purchase via the crowd sale, 5% for the existing MaidSafe investors, 5% for the SAFE core development team and 10% for the general developer pool.
Is these coins going to be available for sales? 5% + 5% ? That’s 100% inflation year 1, without counting the coins farmed. Even if only 5% (to devs) that’s still 50% inflation.
Final remark:
“half the total volume will issued during the first 5 years”
We’re talking 430 million coins per year. This is a massive equity dilution of crowdsale participants and very quickly so.
I rest my case
Yes I am sorry the 50% figure from your very later post was increase in # of coin and not 50% total.
But you did say, which I quoted you earlier where you said most coins will be existing early on and were dismissive of people saying the 90% will take a long time to be issued.
But now by your last post I see you have changed the argument into realistic figures that is much closer to what is expected and I agree that there “could” be an increase of 80 to 250 million coins in the first year.
But there can also be a much smaller increase in the first year since the data has to be first uploaded before any significant gets can be done. Also it costs more to PUT a chunk then the average reward for retrieving a chunk will be. So the net rate could equally be a reduced number of coins for a few months, even 6 or more depending on what people are uploading. For instance people could start uploading their song/movie collections to their private or public files.
So NO, you cannot claim “case closed” on a 50% increase in number of coins existing.
A few points you might want to consider in your analysis
- the number of coins existing could (yes could) be decreasing for a while, even many months or a few weeks - who knows, but there is a strong case for a period of decrease.
- the initial coins existing will be 15% so your calculations for so-called inflation, need to be adjusted.
- increase in so-called miners in the graph does not equate to increase in rate of coin issuance. The coin issuance is related to the number of chunks being retrieved and the amount of available space. There is a indirect connection with the number of farmers because more farmers typically mean more space available which drives down the issuance rate. So in fact too many farmers will result in low coin issuance rates.
- I am lost as to what you are actually trying to say this coin increase will do. If its to refute the $20,000 per coin (or other huge figure) then I am in agreement. As to what the price will be I don’t know, but not the imaginative figures some say.
- the proposed 30% does not exist anymore and has been mentioned a number of times. There is the 10% from presale and 5% reserved for earlier investors. So a total of 15% of coins existing on day 1. Most here know this and will have factored this into any calculations they have personally done.
- The example of bitcoin shows that even with total coin supply increasing steadily, the overall long term price can also increase by large amounts. (Note its an example and safecoin may or may not be similar)
This is a much better response. Thank you.
The 50% figure was just an example. My argument is related to 430 million coins coming out every year on average for 5 years. If you have 10% inflation first year then you need to have a lot more inflation in the following 4 years. It’s not that important if the first year has less inflation than the subsequent years, my argument is based on dilution of crowdsale participants and the fact that by the time we reach year 5 we will be massively diluted and by year 10 completely diluted.
Massive inflation as such could have a negative impact on price versus no inflation (or deflation). And since the inflation is very heavy early on, the launch hype may settled down with a long period of depression due to the huge supply coming into the market.
That’s roughly 195 million more coins than currently exists. 195 million coins extra is 43% inflation on day 1, not counting the farming. (again, the first year isn’t important in my analysis, just saying)
Good point. But the table with the estimates confirms the rate.
It’s not fair to compare a mined coin like bitcoin to a crowdfunded coin like maidsafe. When bitcoin had reached mainstream the inflation was already very low. If inflation had been 12 million every year for 5 years i’m sure the priced would have suffered a lot more.
Year #bitcoins Inflation per annum
2013 12,199,725 13.7%
2014 13,671,200 12.1%
2015 15,029,525 9.9%
2016 16,075,400 7.0%
2017 16,750,400 4.2% (estimate)
2018 17,425,400 4.0% (estimate)
2019 18,100,400 3.9% (estimate)
I find this discussion interesting. But I think it’s important to use accurate terms and generally be as accurate as possible so as to avoid misunderstandings. Safecoin will be “farmed” - not “mined”. Also, keep your cool, guys. ![]()
If one has not factored this in their personal calculations then there is plenty of time to do that. The 15% on day 1 is better than what ICO people expected from the 30%.
So in fact this is a so called deflation from what people who did their homework in the ICO were expecting.
So are we arguing over terms?
Anyhow the current price of MAID should be factoring in the 15% on day 1 into the price. If they are not then shame on their research, but since it was discussed in Poloniex troll box when it existed then I expect most of the traders knew about it.
Yes but I was referring to the label in the graph supplied by the poster.
Old table and the discussions over potential negative growth of coins existing early on (and at times later on) had not been considered when that table was created. So I would argue it is out of date.
Anyhow at the end of the day you have set your views on this massive so called inflation where some others who have done their own research disagree. So for me I think at this stage we might have to agree to hold differing views on what may or may not happen in the first 3, 6 12 months.
Since the algorithms have not been finalised (actually barely started) then this is only discussions and until we get updated algorithms and test data its really conjecture. I am of the opinion that the so called inflation in year one will not be as you presented, but hey it could be if things change.
Also since safecoin is a utility coin used to actually buy tangible product then the price of the coin will not be like what has been experienced elsewhere. And as I said the bitcoin was only an example of what can happen.
This discussion show that you need to sell maid before launch safecoin
Actually I’ve said in the past that my opinion based on the rumour/news cycle that if you get it right then selling before safecoin exchange starts (or maybe just before safecoin implementation) then buying back during exchange might create a winfall profit for people.
BUT BUT BUT it very well may not do that too. It’d be a real gamble.
If the algo testing goes well, and all is completed succesfully.
A huge amount of farmed coins would in my eyes only equal a huge success.
Hopefully it would mean a large amount spent on puts / data stored and good adoption.
I just dont see a problem.
Right, so you confirm that inflation will be minimum 43% year 1, correct? In addition to that 43% comes any potential farming rewards.
Once again you’re back to personal attacks. You really can’t help it, can you? You’re insinuate that I did not “do my homework” because I wasn’t aware of the distribution. The trollbox shut down years ago by the way. Do you expect people to look up the troll box log? or plow through thousands of forum posts with diffuse answers and guesstimates? Expecting this to be common knowledge without it being readily available in a short concrete paper is naive.
Isn’t this supposed to be a friendly atmosphere where we can ask questions, discuss and learn about safe? Or
is it a circle jerk where any criticism is to be shut down with personal attacks until they run of and leave you alone? This project still is very diffuse, most people don’t have time to read thousands of forum posts to get answer to their question. I realize there are still many unanswered questions and that’s fine, but you can be nice about it instead of using this elitist attitude.
More supply is inflation, even if it’s less inflation than originally planned, by the way.
Good to know that “people who have done their research” disagrees. I guess we can close the case then and never mention this again. Right? Is that what you want? Or can you actually give a solid argument as to why inflation of 430 million coins per year does not negatively impact the price?
(you’re talking about the first 12 months, I’m talking about the first 5 years)
So you essentially don’t know anything yet. Why were you so passionately telling me I was wrong then, if it’s not even decided yet? Which one is it?
No one knows anything but everyone has on opinion over something no one knows. I know why i like reading this ![]()
Hello,
It is of course desirable to have as much info as possible about the Safe Network at a central place.
safenetwork.tech is a recent effort to do just that.
You say you weren’t aware of the distribution. You mean the 15%? There is an effort to describe that here: Safe Network
Maybe you’ve already read this and it wasn’t clear enough or too much info to process at once.
No problem for me, just wanted to point out that the distribution info is covered there.
I agree, but its also exhausting. Discussions like this bubble up here all the time, and it gets annoying. I would love to see my investment succeed as does anyone on this thread, but I’ve grown to appreciate the bigger SAFE Network picture, which puts success of the network above all else. It’s importance to humnity is staggering. The potential for true decentralized lateral power sharing is imperative if we are truly entering the age of augmented humanity. That being said 0.22 is a great price to load up. Cheers!
Sumed it up nicely Michael. My sentiments exactly. Just sit back and wait…
Is there a reason that 4.3 billion was chosen as total supply to begin with/a reason why that number can’t be adjusted before the actual token is produced and overall supply set at a much lower number?
