I believe cryptopia.co.nz will work for you. They do not require ID verification and can w/d upto $5K NZD per day.
yea that should work
NOOO!!! They have 29 MAID withdrawal fee, not good for small buys.
Currently MAID is 46 cents and dropping. So that fee is like $13
If you have nowhere else to buy then that has to be paid.
So what is your suggestion?
Its getting close to your desired 40 cents.
You mean $13.34.
Itās not even about bucks. Out of approximately 110 MAID, heāll be getting 80.
Losing ten or 30 is quite a difference in this case, so he should politely ask one of the Polo residents, deposit his dough to their account, pray they are not that crooked⦠as to buy and send from Polo for him.
~Alpha 2 = 12 years , maid 0.46 ā¦Alpha 3 another 5 years Maid 0.26 , Alpha 4 again another 5 years Maid 0.16 , Beta another 10 years Maid 0.000000016
Sorry you are right, I misplaced the decimal
Edited my previous post to fix the erroneous conclusion I made
Programming in earnest only started some 4 years ago. Was refactored some 2 and bit years ago.
So that is like 3 years to alpha 1, another year to alpha 2. On the verge of alpha 3 now with actual programming started recently after design work done. Alpha 4 is effectively being worked on in design now.
So not your analysis is not right.
Try explaining that to the taxman.
Easy decision then. Sell⦠![]()
Thanks, already sold all
Thatās fine, I intend to make most of my MSC running vaults in the early days of the final release candidate. This is purely an investment for now, as I believe MSC is criminally undervalued, under that assumption, paying a 30% fee is fine, since I believe the coin will 10x before I intend to sell any.
Good man. Now you donāt have to complain ![]()
Bought some MAID for my friend.
Now is the time to stock up! Iām trying to get some BTC into an exchange to buy more MAID. Wish it would hurry up!
Where in the world are you located?
If UK you could easily be seen as a trader rather than investor if you do that.
40% taxā¦
The Czech Republic. Weāre the Wild Wild East, so I wouldnāt worry about it in the least.
Fair play. Good luck to you.
If they launch i would not sell for x10 from here for sure. Then i am thinking about dollar 20 at least each.
But i think development will take 2 more years at least, so around that time the whole market can be changed already.
