Can you give us a hint? Is the CEX on that list?
I think it would be good to appear on BitMart, regardless of some top-tier exchanges, because big part of community is already there.
I already took Bitmart for granted.
Get on Coinbase and everything else is a straight layup.
Please also know that Binance and Bitmart are not available in The Netherlands. Any other top-10 exchange will do. Can someone take note of that, maybe @rusty.spork?
We donāt need centralized exchanges, dex crush all cex and from there itās easy to turn to usdc and send them to Revolut directly for example.
Check out the Dev Forum
The problem with DEXs is converting to and from FIAT.
USDC is accepted everywhere. You use UniSwap to sell ANT for USDC and send USDC to a centralized exchange and exchange it for fiat money.
So how does one get USDC?
eMAID is in a pool with USDC. Just click the Swap button:
https://app.uniswap.org/explore/pools/ethereum/0x35593881b7723b39A5bDbcb421e55C1Ff1953F4B
its surprisingly easy using uni swap @Dimitar is right every one should be using DEX exchanges.
just set up a test wallet put £20 in it and play around with it till you get the hang of it before you play with your main wallet.
At the moment, I can swap Emaid directly in Ledger Live wallet. Will this also be possible for ANT do you think?
Ledger live uses 1inch and changelly for trading, so it will also support the Ant token.
it means there are two dex for emaid?
Obviously, Iām not criticizing DEXs, but as you said, a CEX is still necessary to buy USDC and transfer it to the DEX. For people who arenāt very familiar with crypto and want to acquire the networkās token, it will be an additional barrier. In fact, Iāve been in crypto for years, and the first time I used a DEX was precisely to acquire EMAID. Now I like them and prefer them over a CEX, but I used to avoid them out of fear. Whether we like it or not, we need high-volume CEXs if we want the launch to be successful.
I understand what you meanā¦and maybe at some point ANT will be listed on a CEX.
But as you know, if there is no private keyā¦the crypto is not yours.
If one understands that, which is first classā¦why want a CEX???
One has been maintaining oneās anonymity for yearsā¦so that overnight I have to transfer my private data to a centralized entity??
Excuse me?
What chapter have I missed?
When we talk about Dex, we mean two things - an address on Ethereum with special smart contract functions and someoneās server with a user interface.
The Ethereum address can be used by anyone and the Ledger uses two intermediary servers that access the Ethereum address. The Ethereum address in this case is the eMAID/ USDC pool and is used by all intermediaries with a server and user interface. Thatās why itās not 2, but all Dexes for eMAID.
so its same pool but accessible for other interface?
But for someone with ZERO crypto, especially zero erc20 how are they supposed to get USDC
This will be the case with all the new people wanting to use Autonomi with zero experience with crypto
All you showed was swapping again.
That is the question how are people to do that? chicken and egg. Have to have crypto to swap crypto
