Emaid price is 23 cents, regular Maid is a little under 17 cents.
But is there actually any for sale at the lower price? Last time. I checked the order book was pretty thin?
That is because arbitrage don’t work right now since Bittrex Maid wallet is on maintenance. So can’t convert Maid to Emaid for arbitrage.
also, selling emaid on uniswap seems a bit weird to me
How come? thought you just swap and get USDC or similar like when bought Emaid.
well, for example, you cannot place a limit. never used a swap app though so am probably just clueless
Yes it is not good as an exchange, pools seems only convinient to swap coins but not as a substitute for exchanges with orderbooks.
I’m so glad I’ve already bought all the eMaid I wanted before the price jumped up.
I think @Toivo who said yesrerday or so that Bittrex Maidsafe wallet is on maintenance, so Maid deposits and withdraws might not be open at the moment.
Just have them buy eMAID off Uniswap.
You can still buy with btc just can’t withdraw them.
At least he knows where you live ![]()
Just buy the MAID - if you have enough BTC to cover it - the wallets go down for maintenance every so often and are usually available again inside 24 hrs.
IIRC it was offline for a couple of days once but that was a few years back.
Just dont push the price too high please, I am expecting some more BTC tomorrow for further buying <650
Buy them all ![]()
You know from history that you will go russian roulette on them with leveraged positions and gamble it all away, so it probably makes no difference how many you have or get.
Champagne commies go for broke. ![]()
There is no wallet maintenance on Bittrex anymore.
Confirmed - the yellow triangle is gone ![]()
I think the last time I heard about wallet maintenance it took like 2 weeks, the omni protocol takes a long time to rebuild the database
depends on the reason for maintenance. Last time I heard about it in this forum it took a long time which was obviously rebuilding the omni protocol DB
EDIT: and its back up so thats good to hear
You can very easily place a limit order through an uniswap aggregator - for example 1inch:
https://app.1inch.io/#/1/classic/limit-order/USDC/EMAID
Thanks for letting us know. I withdrew all the excess immediately. Though I have to say Bittrex is the one I trust the most. But still…
I think I’m going to convert some more into EMAID. I need to sell some in this year in any case, so the tax consequences don’t matter. The price is also clearly better, at the moment at least, and I guess there could be a shortage of EMAID coming when the interest picks up again.
