EVM Testing for Beta Phase 2 Begins!
That looks like the number of payments rather than the earnings or the amount of a single payment. I’ll be looking into it properly some time soon.
Exactly this - it’s the number that had been used in the past for “adjusting the quoting metric for fairness” …
To know fiat’s ranking, you only have to ask one question, does AI accept fiat on the Network?
No reason to not have 0 fees for ANT on the Network, everything else…
:sweat_smile: PUTs noderunners in their place and don’t give them the idea that they are a
They would seem to be in “attos”. My monitoring script uses the /metrics figure and it shows them as nanos since I have not changed the code to account for 18 decimal places and attos. Its just an integer value of attos for /metrics. IE 10^18 is one token
For anyone using vdash, there is an update which mentions ‘attos’ rather than ‘nanos’.
NOTE: vdash 0.18.1 shows earned attos (so please update from 0.18.0), and don’t go earning more than 2^64-1 or they will disappear :wink:
Once you have Rust, install or update with:
cargo install vdash
vdash -V
# vdash 0.18.1
If you get an error above, please run rustup update and then try again.
More help here: GitHub - happybeing/vdash: A Dashboard for Autonomi Nodes that runs in the terminal
Did you see that there is a log entry that Chriso mentioned that will indicate a node was killed when CPU is over 50% for too long
You can search for “Excess host CPU”
Thanks Rob, I’m not going to enhance vdash for the time being but you can already tell if nodes have died as the status for such nodes will become “INACTIVE” shortly afterwards.
The EVM beta is no success for me. I have only 5 nodes running and my internet connection is slow as sh*t. As soon as I stop the nodes, everything works fine.
I suspect it is a router/Quic issue because I had weird disconnects before, and I opened a support ticket with the vendor for that, but they are not interested to investigate further.
Anyone else with a Fritzbox / AVM with problems?
@mccnex was a Fritz box man I think he said he could only get 10 nodes if I remember correctly.
And he just ordered a Mikrotik ax3
Yeah definitely worse performing this test, I had 60 nodes running from home on the last few tests, I’m down to 30 now and still getting funny looks from the mrs :cold_face:
Interesting!
But could it also be problematic with other router brands?
yeah, I guess you share my misery on this one… I’ve got fiber 1g down / 0.3 upload and fritz 4040, managed to run 10-15 nodes on linux laptop as exposed host, no to bother about opening ports for nodes. always had that reset loop issue when starting nodes, I mean it would restart itself 3-5 times before stabilizing and get me my nodes running and earning, however, depending on testnet, certain amount of nodes was causing issues to my home network, before was running even 30-40 but the more network was getting filled the less nodes would work on my fritz, last testnet in august i guess was those 10-15 i mentioned above… then eventually I gave it up, to avoid noises at home
i was also trying windows launchpad with no port forwarding, it worked and earned but comparing to linux cli was a joke, just did it to give some feedback to the blue coloured guys on discord
Yes I had the same reconnect issues. It was the reason to stop testing for a while because the slow Internet and disconnects were simply not worth it for me.
Getting a new router is a bit too much for me so I’m stuck with this thing…
7 nodes, more than 300GB of data exchanged and not a single Atto. And noticeably affecting the speed of the computer.
Not happy…
Can you confirm that you don’t see a nanos in explorer when you put in your address like it is here: https://sepolia.arbiscan.io/
Check out the Dev Forum
At least some Attos…
Pretty good, I hope you’re happy now :happyant:
I don’t believe it is possible to make an easy to use ETH wallet/exchange that doesn’t sacrifice lots of privacy or require registering your personal details with an exchange. Which completely misses the point of Autonomi. Nobody has ever managed to create one as far as I know.
I wouldn’t count on the native token being implemented at all. And I don’t know how the ETH blockchain tokens can be converted to native tokens which won’t exist on a blockchain at all (hopefully).
The future can be a very long time, infinity in fact. With no fixed date or even a ballpark date waiting for native tokens to arrive before cashing out is not good advice. Crypto is there to convert to cash else there is zero reason to use it at all in autonomi.
