Everything is working fine for me, not sure if it means anythng but the errors in vdash have reduced dramatically also. just uloaded this:
"AnarchyInTheSouthside.mp3" ac236512a18fe03f4f972f4608b48e7262c6a3c5ce5408c3651bdfa4f274fec3
@chriso a clean install looks OK - I’d put it down to quantum fluctuations in the ether or something and not waste anymore time on this
safe@ATTnet01-southside:~/.local/bin$ sudo /home/safe/.local/bin/safenode-manager add --count 20 --node-port 15000-15019 --peer /ip4/209.97.139.230/udp/59695/quic-v1/p2p/12D3KooWPTyqVdNzqcaeNGzjHA4nNnqJWkxU81gW7uBPYewu3jop
Add Safenode Services
20 service(s) to be added
The safe user already exists
Retrieving latest version for safenode...
Downloading safenode version 0.105.6-alpha.4...
Download completed: /tmp/30469841-4aea-4b43-9ee9-4221aee2bb8b/safenode
Services Added:
✓ safenode1
- Safenode path: /var/safenode-manager/services/safenode1/safenode
- Data path: /var/safenode-manager/services/safenode1
- Log path: /var/log/safenode/safenode1
- RPC port: 127.0.0.1:34791
✓ safenode2
- Safenode path: /var/safenode-manager/services/safenode2/safenode
- Data path: /var/safenode-manager/services/safenode2
- Log path: /var/log/safenode/safenode2
- RPC port: 127.0.0.1:39805
✓ safenode3
- Safenode path: /var/safenode-manager/services/safenode3/safenode
- Data path: /var/safenode-manager/services/safenode3
- Log path: /var/log/safenode/safenode3
- RPC port: 127.0.0.1:37543
✓ safenode4
- Safenode path: /var/safenode-manager/services/safenode4/safenode
- Data path: /var/safenode-manager/services/safenode4
- Log path: /var/log/safenode/safenode4
- RPC port: 127.0.0.1:34845
✓ safenode5
- Safenode path: /var/safenode-manager/services/safenode5/safenode
- Data path: /var/safenode-manager/services/safenode5
- Log path: /var/log/safenode/safenode5
- RPC port: 127.0.0.1:39899
✓ safenode6
- Safenode path: /var/safenode-manager/services/safenode6/safenode
- Data path: /var/safenode-manager/services/safenode6
- Log path: /var/log/safenode/safenode6
- RPC port: 127.0.0.1:46499
✓ safenode7
- Safenode path: /var/safenode-manager/services/safenode7/safenode
- Data path: /var/safenode-manager/services/safenode7
- Log path: /var/log/safenode/safenode7
- RPC port: 127.0.0.1:38809
Haha, an extra “t” from a cosmic ray maybe?
BTW - are we supposed to be going easy on the number of nodes started - to leave room for adding others later?
I have started 20 for now.
Not that I’m aware of.
The ants are telling me to go for a pint of Tennants
Im telling the ants to GTF and bring me a nice weissbier.
I’ll add another 20 then.
2 posts were merged into an existing topic: Node Manager UX and Issues
I’m going to sign off for today, but, can you elaborate on your setup please? Are you using the node manager and were able to get services added, but they won’t start?
Any command output would be useful.
safenode-manager add --count 2 --node-port 12000-12001 --peer /ip4/161.35.165.63/udp/56759/quic-v1/p2p/12D3KooWGBCKLkgwv8YWb3KQBwi9fG4GYMWhYcouKSi1TLe6qm3f
2 service(s) to be added
Retrieving latest version for safenode…
Downloading safenode version 0.105.6-alpha.4…
Download completed: C:\Users\CHRIS~1.DES\AppData\Local\Temp\d0a978c8-763e-4dc6-952e-7eda1a840239\safenode.exe
Services Added:
✓ safenode1
- Safenode path: C:\ProgramData\safenode\data\safenode1\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode1
- Log path: C:\ProgramData\safenode\logs\safenode1
- RPC port: 127.0.0.1:62508
✓ safenode2
- Safenode path: C:\ProgramData\safenode\data\safenode2\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode2
- Log path: C:\ProgramData\safenode\logs\safenode2
- RPC port: 127.0.0.1:62509
[!] Note: newly added services have not been started
How many connected peers do you guys have, mine seem very low.
safenode1 12D3KooWL6fy7Vc4GY8ec4ZY8mPfQ3oAmAPzRN7dyTBRyGgBzSfa ←[32mRUNNING←[0m 7
safenode2 12D3KooWNxiPV4MMm4ZXeT9FWsf2GABhEoHWP2LSQzzhqTTVc2Pm ←[32mRUNNING←[0m 11
safenode3 12D3KooWJrPqLu6HDpKQhmZN5Ra48C3CqfujAcb7HwUjUBDgUyJG ←[32mRUNNING←[0m 14
safenode4 12D3KooWCsWa3Tf4hiUEMxSbCdqiiKdoHSWhzhko64JNLy3y9r2H ←[32mRUNNING←[0m 7
safenode5 12D3KooWPKSnJyTR3ZjXZpzGYa56UceVyjg3j3yV4QymPh4pBF8d ←[32mRUNNING←[0m 9
Also Chris before you go, is the correct?
safe wallet balance --peer-id C:\ProgramData\safenode\data\safenode5
If so, I also have no rewards.
I just started another 20 nodes with no problems
safe@ATTnet01-southside:~$ safenode-manager -V
sn-node-manager 0.7.4-alpha.1
some folks were having trouble with >50 nodes IIUC
Ran again because I noticed it’s using a different peer, same result but it only added 1 node this time round…so 3 services are present, expected 4…none will start
safenode-manager add --count 2 --node-port 12000-12001 --peer /ip4/209.97.139.230/udp/59695/quic-v1/p2p/12D3KooWPTyqVdNzqcaeNGzjHA4nNnqJWkxU81gW7uBPYewu3jop
Download completed: C:\Users\CHRIS~1.DES\AppData\Local\Temp\ad220275-bfc5-478c-911a-9b6793606a3c\safenode.exe
Services Added:
✓ safenode3
- Safenode path: C:\ProgramData\safenode\data\safenode3\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode3
- Log path: C:\ProgramData\safenode\logs\safenode3
- RPC port: 127.0.0.1:62557
✓ safenode4
- Safenode path: C:\ProgramData\safenode\data\safenode4\safenode.exe
- Data path: C:\ProgramData\safenode\data\safenode4
- Log path: C:\ProgramData\safenode\logs\safenode4
- RPC port: 127.0.0.1:62558
Edit: There are indeed 4 services, had to relaunch Task Manager to see them, a refresh within the program did not show…
Your number of connected peers are also low, I am not alone.
…on windows?
These have only been started 2-3 mins. I started 2 lots of 20 a couple hours back and vdash says they have 143 - 165 peers.
@happybeing ‘r’ to refresh the log path doesnt seem to work anymore. I raised an issue on Github.
restarted vdash all nodes have good nos of peers now.
What --peer-id did you use?
#WFM
Also - just tabbing through the nodes, I am seeing a lot less red than previously - very few errors indeed.
Congratulations to the Autonomi staff for successfully juggling two testnets at the same time!
Had 100+ peer within minutes of starting (manually) using peer /ip4/161.35.165.63/udp/56759/quic-v1/p2p/12D3KooWGBCKLkgwv8YWb3KQBwi9fG4GYMWhYcouKSi1TLe6qm3f
I have had over a hundred at times but also as noted earlier they were fluctuating like mad.
Thats what I am accustomed to too.
I’ll add some linux nodes in the morning and see if they behave the same. I have not had these issues before.
