Is there a Powershell command to get the rewards flowing? Maybe they happen eventually, but I feel like maybe it’s turned off currently.
you just make sure the --owner .discordUser is set. thats it.
what is your discord id (get with /get-id on discord)
Lets say it is abcde
then owner option is
--owner abcde
No extra "."s
For safenode-manager you add nodes with
safenode-manager add --owner abcde --count 10 --home-network
as an example of 10 nodes and home network instead of port forwarding. Change home-network to node-port if you port forward, open firewall, etc
For the launcher, hit ctrl+b and enter abcde as the discord ID
Must admit, I was expecting much more wailing and gnashing of teeth cos this weeks leaderboard has failed to appear yet.
Yes I know its a complex one, with lots of activity over past few weeks to be accounted for. Only to be expected that it would take a while.
Still, the restraint is admirable…
As always its there when I wake up.
How late was it? They aim for like 6pm UK time +/- some hours
it was about +3 hours ![]()
Well we got it tonight, not Monday so Im happy ![]()
How do I halt all my nodes through Powershell? I need to shut everything down. I thought things were actually shut down but I guess not.
Edit: I solved it. So, the 3.11 Launchpad says to hit Ctrl+X to Stop All Nodes. Pressing it did nothing for me. I coincidentally randomly tried the Ctrl+G Manage Nodes option, and that ended up stopping every single node. Not sure if this is just me, whether it’s either me doing/understanding something incorrectly, just having this issue myself, or if it is these two different functionalities needing to be swapped in the program. Here’s what my Launchpad looks like immediately following me hitting Ctrl+G:
Doing ctrl+r (reset) is probably best if you have to shut things down
Also launchpad can wrongly indicate the status. See my answer in discord for other info. Gets hard answering in two separate places.
