ThePriceIsRightNet [14/08/23 Testnet] [Offline]
My 4 MB test file is still downloadable.
It works for me.
Uploads are still running smoothly (see below).
I just uploaded a 2.14GB folder with 963 photos in about four hours without any errors.
I have downloaded some photos randomly, for testing, without problems although the initial peers found is a bit slow.
But something weird happens to me with a file I tried to upload yesterday.
I got the following error:
Failed to store all chunks of file ā€˜Zoiper5_5.6.1.pkg’ to all nodes in the close group: Network Error Could not retrieve the record after storing it: 5fd565a5b9596861a9ddf753f2a0ffd997cae59a34a9b59e461bba2327a28871.
Today I tried to re-upload this same file and I got the following errors:
First attempt
Failed to store all chunks of file ā€˜Zoiper5_5.6.1.pkg’ to all nodes in the close group: Network Error Could not retrieve the record after storing it: af60c34525354cc9cb02e0e1efa61826f0b9e98b8e6a079d9b53982f381827b6.
Second attempt
Failed to store all chunks of file ā€˜Zoiper5_5.6.1.pkg’ to all nodes in the close group: Network Error Could not retrieve the record after storing it: 87bda0faa93cdf58ab45a1d7c328dec34b1a5833bb35f02bfaf598a91c598602.
There seems to be no way to recover from the first failure.
If anyone wants to try to upload this file, you can download it from here, Mac version:
FYI. Windows really didn’t like Client version 0.80.41. Was able to upload and download a couple of files yesterday before safe.exe was quarantined. Uploaded and scanned safe.exe online and it came back clean, so I created an exemption for the directory where safe.exe resides and it’s been fine since. I’ve participated in most all the testnets and have never seen this happen before.
Inadequate reaction of antiviruses to rare files is common thing.
@joshuef Do nodes receive any of the payment and if so is there anything that can be picked out of the node log?
And thanks for another testnet!
at the moment I’m like this
Preparing (chunking) files at ā€˜/home/koan/ImĆ”genes/Zoiper5_5.6.1.pkg’…
Making payment for 572 Chunks that belong to 1 file/s.
Successfully made payment of 2288 for 572 records. (At a cost per record of Token(4).)
Successfully stored wallet with cached payment proofs, and new balance 99.999997196.
Successfully paid for storage and generated the proofs. They can now be sent to the storage nodes when uploading paid chunks.
Storing file ā€˜Zoiper5_5.6.1.pkg’ of 291971984 bytes (572 chunk/s)…
Weird…Those Chunks are supposed to have been paid for and you should get the message:
No payment needed for 572 records.
Let’s see what the Devs have to say…
Well it seems that the nodes that correspond to me have been closed.
Built with git version: aba95fb / main / aba95fb
Instantiating a SAFE client…
:link: Connected to the Network Loaded wallet from ā€œ/home/koan/.local/share/safe/client/walletā€ with balance Token(99999999484)
Failed to store all chunks of file ā€˜Zoiper5_5.6.1.pkg’ to all nodes in the close group: Network Error Could not retrieve the record after storing it: 2e973be4a20e937118a3e4930667eca3aad5d9a20141d5f2e01153423f393756.
Writing 65 bytes to ā€œ/home/koan/.local/share/safe/client/uploaded_files/file_names_2023-08-15_16-45-42ā€
Not yet Mark. The payment is made but not transferred. That’s coming soon though. I hope we remember to ping you the appropriate log beforehand
Yep…same error I get except the numbers change.
I was able to download your file filename.mkv bc26e6cc55a715ed69bfafcedc64c0d356b5c09b7a37fd75509b60f52163b342,
375 M
Now this is not possible 278.4 MiB
What could be the cause ?
Aye atm, you’ll never pay the correct price if your first proofs were cheaper. Fix coming for that :+1:
They don’t receive it. You can see how much they would receive from the logs in the OP:
So very welcome!
edit: added some update info to the OP there.
The size of the MKV should be 393,170,097 bytes exactly.
finished downloading 278.4 MiB (291,971,984)
Really not having any luck with this testnet, can’t upload, 19.999999993 from my balance was from the previous testnet (I was too lazy to remove it)
eddy@Hal9000:~$ safe files upload /home/eddy/Fw.jpeg
šŸ”— Connected to the Network                                                     Loaded wallet from "/home/eddy/.local/share/safe/client/wallet" with balance Token(119999999993)
Preparing (chunking) files at '/home/eddy/Fw.jpeg'...
Making payment for 4 Chunks that belong to 1 file/s.
No payment needed for 4 records.
Successfully stored wallet with cached payment proofs, and new balance 119.999999993.
Storing file 'Fw.jpeg' of 132454 bytes (4 chunk/s)..
Failed to store all chunks of file 'Fw.jpeg' to all nodes in the close group: Network Error Could not retrieve the record after storing it: 3ee05206a8216b14359515a07bf33ddb6d250f3cf0d0e29f7b6f8f3be877826b.
Writing 55 bytes to "/home/eddy/.local/share/safe/client/uploaded_files/file_names_2023-08-15_18-41-52"
My node also keeps dropping every time
Luckily I could download
:beers:
Great to see the change up of droplets in 5 different locations, would be fun if the Maidsafe nodes could be copied as images in the future.
Will keep trying
Keep hacking super ants
Hi @mav I know it’s not the most important issue in the world, but I just wanted to follow up on this.
The ~/.safe path is not something that’s in use any more. The dirs-next crate is used to supply default locations that are based on the XDG specification for Linux and standard directories on other operating systems. The directories split out configuration and data, which I personally think is useful.
To be completely accommodating, we could possibly support the use of environment variables that allow users to override these locations, but I don’t know if it would be a particular priority at the moment.
Chunk price starts to rise…
Successfully made payment of 3040 for 190 records. (At a cost per record of Token(16).)
I’m still getting just 4 tokens per chunk. Are you using the latest client code?
willie@gagarin:~$ time safe files upload /fgfs/Aircraft/MD-80
šŸ”— Connected to the Network                                                     Loaded wallet from "/home/willie/.local/share/safe/client/wallet" with balance Token(99999986586)
Preparing (chunking) files at '/fgfs/Aircraft/MD-80'...
Making payment for 3104 Chunks that belong to 843 file/s.
Successfully made payment of 11224 for 2806 records. (At a cost per record of Token(4).)
Successfully stored wallet with cached payment proofs, and new balance 99.999976754.
My first upload (slow as treacle) and got,
Successfully made payment of 32 for 4 records. (At a cost per record of Token(8).)
@digipl getting (16), you (4) and me (8). Is it that more nodes were added and the price dropped or that the nodes @digipl and I stored our data at held more data and charged more.
Seems problematic if one person pays 4 times what another does cause the nodes in his neighborhood have more chunks and are charging a premiuim.
You’ll have to remove it. It won’t be valid on this testnet. (That should be covered by the cleanup section in the OP)
