ThePriceIsRightNet [14/08/23 Testnet] [Offline]
I almost sure that it will and I don’t see (yet) how can it help solving problem.
I know that physical network is relatively fine at my location and with exactly the same settings node was getting records in previous testnet.
Do you mean this line?
[2023-08-14T14:45:23.678876Z INFO sn_networking] Node (PID: 12108) with PeerId: 12D3KooWSw1CAYjPquS6qQ6RxWmGewqUWUraTqr7kCe31cGjUfwY
Well, if it does connect, we know that. If you are consistently unable to start a node that joins, that tells us something else… So we can dig in there.
Yup, that’s the one. :bowing_man:
It created 64 log files today each about 1.4 to 2MB in size … where do you want’em!?
Just one from a failing run should be fine thanks :bowing_man:
Where though? I can’t attach it here - the forum software doesn’t allow it.
More oops :frowning:
willie@gagarin:~$ safe files download file.mkv bc26e6cc55a715ed69bfafcedc64c0d356b5c09b7a37fd75509b60f52163b342
Built with git version: aba95fb / main / aba95fb
🔗 Connected to the Network                                                     Downloading file "file.mkv" with address bc26e6cc55a715ed69bfafcedc64c0d356b5c09b7a37fd75509b60f52163b342
Client download progress 12/768
Client download progress 18/768
Client download progress 23/768
Client download progress 26/768
Client download progress 30/768
Client download progress 35/768
Client download progress 39/768
Client download progress 42/768
Client download progress 49/768
Client download progress 53/768
Client download progress 54/768
Client download progress 55/768
Client download progress 56/768
Client download progress 57/768
Did not get file "file.mkv" from the network! Chunks error Not all chunks were retrieved, expected 768, retrieved 57, missing [9fb857(10011111).., 5df7b1(01011101).., etc etc
You should be able to zip it and send it, I think.
Aha! Thanks for that tip.
safenode.log.20230815T124830.zip (203.4 KB)
Getting some electrical work done today and the power went off a couple of times. I had a 362Mb atttepted upload running that got interrupted. WHen I try again, it did not attempt to charge me twice :slight_smile:
No payment needed for 710 records.
🔗 Connected to the Network                                                     Loaded wallet from "/home/willie/.local/share/safe/client/wallet" with balance
Token(99999986586)
Preparing (chunking) files at '/home/willie/Videos/cooking/madhur/madhur05.avi'...
Making payment for 710 Chunks that belong to 1 file/s.
Successfully stored wallet with cached payment proofs, and new balance 99.999986586.
Successfully paid for storage and generated the proofs. They can now be sent to the storage nodes when uploading paid chunks.
Storing file 'madhur05.avi' of 362742180 bytes (710 chunk/s)..
For a minute or two I was getting much better network response , not great but better…
red lines is upload.
Actually, you’re hittong on a potential issue we have with repeat uploads.
If payment was insufficient for some nodes, we may not hit quorum. And as you see here, a future upload attempt will not (currently) retry to pay!
Which means you’ll never get your data up right now.
So we’re working on a few fixes there. Hopefully we can get a new client out to test against this network. (If we have a good looking node-fix for these 0 record nodes, we’ll maybe just start fresh).
OK - should I stop that job or let it continue and grab the logs?
I will kick off another fresh upload anyway.
EDIT: No I won’t – power going off while the datacentre err err garage gets hooked up
That explains my problems above; I started uploading early when price was 2 tokens.
Can look for the client logs if needed
:muscle:
I was wrong.
Second node shows the same behaviour as first one - it still got no records.
[2023-08-15T08:26:05.102657Z INFO sn_networking] Node (PID: 6920) with PeerId: 12D3KooWJtCYJsjL9Px6pxEmj9AQBR4ZLjXtySKHJ9ATZeCkY8kQ
However, I don’t know what conclusions can be made from this information.
(I did not figured out yet how to launch several nodes at the same time in Windows service mode, so I’m not planning to launch more nodes at this moment)
I have continued testing, in general everything is fine :clap:
Received without problems, maybe a bit slow
filename.mkv bc26e6cc55a715ed69bfafcedc64c0d356b5c09b7a37fd75509b60f52163b342,
~/Southside.jpg 36a1834fa03c7f3b5c635e48ecb21da0c9ada28fc1380be9940be57f97eb94d2
If anyone wants to try one I have uploaded 43 MiB myself
salma.mp4 8f71cfa3a5054b4ee3f82335b3ddc60f85070e0bb07801373103bfb742759ea9
with more time I will start a node
I’m not having much luck with this testnet…
willie@gagarin:~$  time safe files download salma.mp4 8f71cfa3a5054b4ee3f82335b3ddc60f85070e0bb07801373103bfb742759ea9
🔗 Connected to the Network                                                     Downloading file "salma.mp4" with address 8f71cfa3a5054b4ee3f82335b3ddc60f85070e0bb07801373103bfb742759ea9
Client download progress 31/89
Client download progress 55/89
Client download progress 80/89
Did not get file "salma.mp4" from the network! Chunks error Not all chunks were retrieved, expected 89, retrieved 80, missing [c159dd(11000001).., abd703(10101011).., 31eb50(00110001).., 53e496(01010011).., 796d38(01111001).., 86e21b(10000110).., fe9923(11111110).., 971932(10010111).., efcd93(11101111)..]..
real	2m42.516s
user	0m13.211s
sys	0m3.506s
EDIT: and failed again…
Client download progress 29/89
Client download progress 57/89
Client download progress 82/89
Did not get file "salma.mp4" from the network! Chunks error Not all chunks were retrieved, expected 89, retrieved 82, missing [a41cc3(10100100).., 3a1966(00111010).., 7dd96b(01111101).., 86e21b(10000110).., fe9923(11111110).., 7050e9(01110000).., efcd93(11101111)..]..
real	2m41.539s
user	0m13.333s
sys	0m3.013s
Always look on the bright side… I got two more chunks on the last try.
Well, maybe by the third time you’ll get the rest down. :laughing:
have you also had problems with the other files to download ?
Sadly no - the third attempt failed as well
Client download progress 54/89
Client download progress 79/89
Did not get file "salma.mp4" from the network! Chunks error Not all chunks were retrieved, expected 89, retrieved 79, missing [5cca90(01011100).., e430fe(11100100).., 613d30(01100001).., 53e496(01010011).., d2e552(11010010).., 796d38(01111001).., 86e21b(10000110).., fe9923(11111110).., 7050e9(01110000).., 971932(10010111)..]..
real	2m43.450s
user	0m13.226s
The only succesful files I downloaded was @TylerAbeoJordan .s FatherJack and a few trivial uploads of my own.
Anything over ~1MB has failed IIRC.
@aatonnomicc - stick up BegBlag if you can, please, thats ~15Mb
BTW has anyone downloaded salma.mp4 successfully?
EDIT: Its getting worse with each attempt - only got 78/89 on the last attempt.
Did not get file "salma.mp4" from the network! Chunks error Not all chunks were retrieved, expected 89, retrieved 78,
That’s what I’m asking myself ?
Yes, I just finished downloading salma.mp4:
PS C:\WINDOWS\system32> Measure-Command {safe --peer=/ip4/134.122.106.147/tcp/41587/p2p/12D3KooWDSeWaBgxMiwboN8jktSaJLg4n8ETx9BuD3f1HiQFk3ka files download -- salma.mp4 8f71cfa3a5054b4ee3f82335b3ddc60f85070e0bb07801373103bfb742759ea9 | Out-Default}
Client download progress 32/89
Client download progress 64/89
Client download progress 89/89
Successfully got file salma.mp4!
Writing 45203917 bytes to "C:\\Users\\Eric\\AppData\\Roaming\\safe\\client\\salma.mp4"
Days              : 0
Hours             : 0
Minutes           : 2
Seconds           : 21
Milliseconds      : 42
Ticks             : 1410423726
TotalDays         : 0.00163243486805556
TotalHours        : 0.0391784368333333
TotalMinutes      : 2.35070621
TotalSeconds      : 141.0423726
TotalMilliseconds : 141042.3726
Let’s try this, it’s 1.5 M
exorcista2.gif a80e7517e0d54b745363c32693add33f4d846938b13e48cef85a4d9503f5c662
