Just got a safe vault running on my Nexus 6. It was a bit of a hack and requires root with Linux Deploy. If there is any interest I will do a tutorial on how to set it up.
EDIT: Tutorial (root is required). There are a few other options for linux on android that don’t require root but I was not able to get them to install successfully.
Sorry to keep you all waiting!
Requirements:
- Phone running Android
- Internet connection
Step 1: Download and install Linux Deploy (this will take a while).
Step 2: Start Linux Deploy and install BusyBox from the link within.
Step 3: Click the download button seen at the bottom right of the Linux Deploy screen.
Step 4: Edit user information as you wish.
Step 5: Click to install and press ‘OK’ on the popup window.
Step 6: Wait for Linux to download and install…
It will be done when the below is shown.
Step 7: Go to the Linux machine settings and “Update ENV.”
Step 8: Start the Linux machine and ensure the SSH server does not fail.
Step 9: Install any SSH client on your phone, I have used JuiceSSH for this tutorial.
Step 10: Open JuiceSSH and add new connection with the address 127.0.0.1, port 22 and a new profile.
Step 11: Use the user information we changed in step 4.
Step 12: Start the SSH session.
Step 13: Accept all RSA warnings.
Step 14: Install curl with sudo apt-get install curl.
Step 15: Download and unzip safe_vault-v0.9.0-armv7.tar.gz with
curl -kL https://github.com/maidsafe/safe_vault/releases/download/0.9.0/safe_vault-v0.9.0-armv7.tar.gz | tar zx
Step 16: Navigate to the safe_vault-v0.9.0-armv7 directory
cd safe_vault-v0.9.0-armv7
Step 17: Start your vault!
./safe_vault
