Introducing svm or SAFE Vault Manager. A small GUI tool to run and manage multiple vaults.
This is currently very rough around the edges, be forewarned.
Install git clone https://github.com/Infining/svm.git //or download zip from Github cd svm npm install
Then copy the contents of the official vault folder to a folder in svm called safe_vault/. The folder structure should be …
svm/safe_vault/safe_vault or safe_vault.exe svm/safe_vault/log.toml svm/safe_vault/safe_vault.crust.config
aaaaaaaaah - that was what i forgot about it! yes - now i get a PID and i seem to have messed up the community network config file because my node only sais “running listener” when started Oo
It’s a great idea and community1 is ideal testing for it.
Today we have dealt with the problem of someone either running a vault with teh wrong network name, or (more likely) running incompatible software (newer vault or launcher).
@Viv has promised to patch the software against this problem (incompatible nodes should simply be ignored). I don’t know when that will be published.
In the meantime I have moved the seed vault to another port (that solved it!) and adding back members one at a time.
My apologies for the inconvenience. We will return to normal service shortly.
