SAFE vault 0.8.0 ARM crashes with illegal instruction
I tried to run the vault binaries on an ARM server and it’s just erroring out with illegal instruction. Is there something I’m doing wrong or has anyone else gotten it to work on an ARM?
uname -a Linux scw-7c2d7c 4.4.0-std-1 #1 SMP Wed Jan 20 13:27:11 UTC 2016 armv7l GNU/Linux
ARM is still quite experimental - would it be possible to log this as an issue in github > https://github.com/maidsafe/safe_vault/issues?
I can log it as an issue, sure, is there any more information you’d like about the platform I’m running it on or is this sufficient?
Thank you that is extremely helpful - as much information as you can log helps the Devs out so the Error / device / linux flavour and version - Cheers :slight_smile:
