We are delighted to announce the immediate availability of the alpha release of the SAFE Network ![]()
This is a client-only network, meaning that users cannot run vaults (contribute their resources) from home yet, all data will be hosted on a vault (p2p) network managed by MaidSafe. The ability for users to run their own vault will be enabled shortly.
Network storage during alpha phase
Data on this alpha network may get lost and MaidSafe will decide or require to wipe the data and restart the network with each alpha release. We will communicate these events via the SAFE Network Forum and on MaidSafe’s blog.
Limitations
This alpha release has some technical limitations (see the Limitations section below).
SAFE Launcher v0.8.0 – Alpha 1
Download
Documentation
Changelog
- Set UI log file path from config handler
- DNS API - removed isPrivate param and replaced with rootPath
- NFS API - restrict root directory deletion
- Start up grey screen fixed
- Log list rendering optimisation
- API - ISO time format fix
- CSP header errors resolved
- Proxy hanging on application crash resolved
- Clear application UI state on logout
- Packaging fixes
- Minor style fixes
SAFE Demo App v0.6.0 – Alpha 1
Download
Documentation
Changelog
- Compatibility with launcher 0.8.0
- Rename files and folders
- Cut/Copy files and folders
- Packaging fixes
- Minor style fixes
SAFE Launcher API v0.5
Documentation
Limitations
Here are the technical limitations of this alpha release:
When uploading files using SAFE Demo App, the maximum file size is 25 MB per file.
Each client account is limited to 500 PUTs. A PUT is a request to store a single chunk on the network (a file may contain many chunks). The maximum chunk size is 1 MB.
Users can’t run their own vault. To allow developers and users to use the SAFE Launcher API without losing data or seeing performance issues, MaidSafe manage all the network nodes. This network is client-only and uses a unique private network name.
When will I be able to run my own vault?
We will release a separate test network for users who want to try out running their own vault. It will be called TEST 8 and will be enabled on August 23.
The reason why we will have two networks running at the same time is because we want to enable users (both existing and new) to discover the software and the features (e.g. uploading data to the network) while not causing issues for app developers who are trying to use the SAFE Launcher API.
To ensure that the Alpha network will provide a good end-user experience as well as a stable network for app developers, we are running 200 nodes on DigitalOcean.
As for TEST 8, its performance will likely not be as good as the Alpha network, but the goal is just to minimally test the network until all the refactors and RFCs (disjoint groups, data chains, etc.) are implemented and tested. At this point we will revert back to having one network.
The reason why we are only releasing TEST 8 on August 23 (and not before) is because we want to avoid confusing new users with multiple install options.
Support
If you need help with anything related to SAFE Launcher, SAFE Demo App or the SAFE Launcher API, please use the Support category.
We anticipate having a lot of new users, so please try to be as helpful and welcoming as you can ![]()
Where should I report issues?
GitHub is the best place to report issues and bugs. Using GitHub will help us (MaidSafe) manage issues and prioritise work within the Dev team faster.
