I think the ms01 is way way way overspecced to be used as a router for home.
maybe @Shu can shed some light on what specs to consider for a.dedicated router appliance ?
Im building an opnsense router on a hp T730 thin client with 8g ram and a dodgy inspur dual 10g nic that prevents the box from booting (grrrrr). But now on hold till a proper dell dual 10g nic is delivered.
Exactly, I’m thinking handling up to 2M NAT entries, for something like 2K nodes (1M entries might be fine since I’ve observed that each node fill about 500 entries).
Also, maybe I’m overestimating what my connection could handle (8Gbit/s symmetrical), but I’d say 2K nodes would be okay (but hard to predict how it will behave once the network is launched).
I have 5 routers. Most overkill but when we set out on this journey there was not much info to go on. I like the MikroTik RB1100AHx4, I have 2 of them. Then I have that CCR that was just crazy heat of the moment purchase.
Also have a couple L009’s.
Any generic hardware (intel / amd / arm) architecture with pfSense or equivalent (most hardware nic’ should be supported by freebsd if they contain mainstream enterprise NIC chipsets).
I run an old box which needed an update to 6 core x 3.3Ghz (turbo to 4.5Ghz) with 32GB RAM.
The local flock is about 50 strong. We have so much greenery that they have no need to chew the cables fortunately. But out west its a real problem to protect the cables.
Just ordered another refurbished 1.5TB RAM server this weekend, as I managed to find another 600W off unused power at home…
The server will be partially for safe nodes, and partially to serve as another HA endpoint for CEPH’s MDS daemon (its steady state is a ton of RAM usage that only a few off my machines have the capacity to serve that daemon properly), but due to needing to support rolling reboots for OS patching purposes, without downtime, I need to have a few MDS daemon(s) in standby state etc.
I guess I am going to find out in a week or so if the current router is itself the bottleneck at 1.5M state table size or not…
If not, it will be exciting to see it cross 2M+ state table size… .
