sure - and it’s not like this would bring beneficial functionality ![]()
Yeah, you can customize the path where the data gets stored.
If you’re using safenode directly, pass in this arg, --root-dir <path>
Or if you’re using the safenode manager, use this arg, --data-dir-path <path>.
Chunking at home simply with
safenode --home-network --peer /ip4/142.93.46.42/udp/43338/quic-v1/p2p/12D3KooWSaCWsF2qLULtKTtjJPYpzCKn3X3aY19WdznPB5jUfmt3
This is indeed a Great Leap Forward. Thank you to The Great Helmsman and all his crew.
All in due course - this is distinctly non-essential right now
You might also want to check if your nodes are getting paid, i.e., clients should be able to PUT to your node.
Home nodes do easily get the replicated data from other public nodes, but receiving the PUTs (from clients) seems to be the hard part. So if we’re getting those, we’re all good ![]()
initially wanted to wait for the node-manager to be updated … but couldn’r resist after your screenshot here ![]()
now running node from home as well! having 88 records, 99 puts and 7 gets so far
… very nice
edit/ps:
already earned 33 nanos from home
We are getting close now.
Reassuringly non-zero ![]()
willie@gagarin:~$ safe wallet balance --peer-id=12D3KooWJ5GUFNvHkSdjgoUMsAK5B3wxjvgM3thMGzBj7ribGa5E
Logging to directory: "/home/willie/.local/share/safe/client/logs/log_2024-04-25_14-28-16"
Built with git version: 15b2690 / alpha-punch / 15b2690 / 2024-04-24
Node's rewards wallet balance (PeerId: 12D3KooWJ5GUFNvHkSdjgoUMsAK5B3wxjvgM3thMGzBj7ribGa5E): 0.000000070
i’ve made the reset of the safenode-manager services. What’s the peer that the safenode-amanger should connect to?
safenode-manager add --count XYZ --peer /ip4/142.93.46.42/udp/43338/quic-v1/p2p/12D3KooWSaCWsF2qLULtKTtjJPYpzCKn3X3aY19WdznPB5jUfmt3 --version 0.106.0-alpha.4
safe node manager is working without a peer specified for me ![]()
think there was an update can you confirm @chriso
oh ok so i can just launch the command safenode-manager add --count x without specifying the peer
worked for me and they are geting putting and earning ![]()
is this just for me or has bandwidth usage decreased a lot since the last testnets? (or is my reference just scewed a lot because of the looping issues we’ve seen that won’t happen now anymore)
I’ll be all over this this weekend! Yaayyy!
seeing the same here all my carefully calculated node joining intervals are out the window as well.
50 nodes joined with 11s interval without issue ![]()
Wow amazing, to wake up to a new testnet
Thx Maidsafe devs
and keep hacking/testing super ants
still confused on why vdash still doesn’t show anything, Node Uptime: start time unknown. It’s like it does not see the node’s logs. Tried to uninstall it, reset the safenode-manager services and reinstall it but nothing has changed
This error is new for me…
Error:
0: Failed to upload chunk batch: The maximum specified repayments were made for the address: cfab81(11001111)…
Yes I see the same. Tried uploading one file of 1.5GB. Also fails the second time.
