GHey guys what does this mean? sorry I really need these BTC and idk any other group who uses OmniWallet
Sorry, all fixed ![]()
just imported my keys into another wallet.
jeez this one can be buggy
I am not sure, I would think you should jump over to the Omni support site though and ask if you are in a hurry.
Maybe your are trying to send the entire balance of an address without allowing a little for the fee?
also you can take your private key; and go to blockchain.info since you are sending btc.
Thanks everybody!
@dallyshalla thatās what ended up working
@chrisfostertv thanks too! i tried different values for the fee but nothing seemed to wirk
I had exactly the same thing happen and hopped over to blockchain.infoā¦but its been 24 hrs and counting and still no transaction confirmsā¦the blockchain does have about 19k transactions pending thoughā¦cant wait for SAFE so I can get away from the lag and double spend issues with BTC!!!
Yea my shapeshift conversion to MAID took ~19 hours a couple of days ago and Iām very interested to see how long it will take for three more today.
Just FYI, I contacted OmniWallet and they released a patch to fix this issue going forward. Yay!
Is there an alternative to OmniWallet? It would sure suck for OmniWallet to break or get hacked right before Maidsafe and Safecoin releasesā¦
Does anyone know of a paper wallet that supports mastercoin/maidsafecoin?
You can send your maidsafe/mastercoins to any bitcoin address, and then just import the privet key into omniwallet when you want to transfer them again. @Doomedj2008
@ejinte I think @Doomedj2008 question was if there is an alternative if the ONE option to send our MAID to SAFEcoin wallets once released.
I for one have only kept a very small amount of MAID in a omniwallet and the majority of my MAID is in cold offline storage. It will be a stressful day/week when I begin the migration.
I was answering his second question. Anyway, according to http://www.omnilayer.org/ you can also use holytransaction. There should also be a desktop client, āomnicoreā however that link is dead.
