#MeToo - we will get on famously - DMs it is then…
Which is precisely why it cannot ever be shown in Scotland. Our broadcasting is only ever allowed to tell Scots how shite they are at everything.
Always tickles me when folk say that…
“please let us undress together for a moment”…
oh man I have gremlins undressing with me right now. bloody things, coming out of nowhere.
I haven’t owned a TV set in decades, and I don’t do Netflix or any of those scams. I’ll use my own ways of getting whatever movies I want until the commercial entities start servicing me properly, instead of e.g. blocking paid subscriptions when people travel. The Finnish paid for by taxes internet TV is also a sad joke. E.g. they won’t let me use a VPN at all if I want to watch their stuff, so they can just keep it. There are other ways.
Joined with
safe node join --skip-auto-port-forwarding
@chriso is there a way to specify node location other than .safe/node/local-node
? Can’t find anything as such in safe node join --help
@Josh - is it down now?
willie@gagarin:~/.safe/node/logs$ safe networks switch comnet
Switching to 'comnet' network...
Fetching 'comnet' network connection information from 'https://sn-comnet.s3.eu-west-2.amazonaws.com/node_connection_info.config' ...
Error:
0: EOF while parsing a value at line 2 column 0
yes fighting gremlins, they are winning right now
OK don’t sweat. You have put in a hard shift. Maybe we should just wait until the merge and try again on the 24th.
Thank you for all your efforts.
I have a bit of time left, I think it merged but no release yet
If you have time, please DM me the command you used to set up the genesis node.
I will then attempt to run this on a single node on an AWS t2 micro and try to connect from home to double check the --public-addr ip:port issues I tried to commnicate to @chriso earlier.
Everything is down right now and it is of course the moment my wife starts feeling as if I am not participating in raising the kids.
There’s a --node-dir-path
argument that points to the directory where you’ve installed the node. Otherwise it’ll assume it’s at the default location, which is ~/.safe/node
Is that what you mean?
Go do family stuff - it’s usually a smart move, short or long-term.
THis can wait - Despite what I said earlier, its been 15 years
as always great effort @Josh go spend some time with your troops and keep the wife sweet we will still be here when you are allowed out to play again
No, sorry, I meant a flag to indicate where node chunks would go, which by default is .safe/node/local-node
Ah ok, thanks.
At the moment, the --root-dir
argument (poorly named in my opinion) of the binary is not exposed on the node join
command. We can add that (though I would prefer to call it something like --data-dir-path
). We aren’t exposing --log-dir
either on node join
. Perhaps on the node join
command, we can have:
--data-dir-path
for the path of the data directory -
--bin-dir-path
for the path of the directory where the binary is (at the moment this is called--node-dir-path
, but I think the word “node” is redundant in this context, since if we’re on anode join
command, we know the argument relates to the node) -
--log-dir-path
for the path of the logs directory
That’s probably what I’d prefer. Not sure it will get done on this side of the year though. Maybe this week if I get time, but I’m gonna take a holiday after this week.
New version of the CLI is available for the next test.
I wondered about that myself but decided you guys knew best…
Much better. Thank you
I would like a step by step guide to start a community network myself, anyone on the task?
