OFFLINE Will it be a Quicky? (run 4)
renaming to josh-run5.sh
Find this out by running the join command then scrolling back up to about 3 lines from the top and looking for your own external IP and the then get the port that was assigned
@Southside will it help you if i set up a small network for you to refine a script?
Very much - I am failing to download the connection_info config for comnet from
safe networks add comnet https://sn-comnet.s3.eu-west-2.amazonaws.com/node_connection_info.config
Switching to ā€˜comnet’ network…
Fetching ā€˜comnet’ network connection information from ā€˜https://sn-comnet.s3.eu-west-2.amazonaws.com/node_connection_info.config’ …
Error:
0: expected value at line 1 column 1
/rustc/f1edd0429582dd29cccacaf50fd134b05593bd9c/library/core/src/result.rs:1914
Ok, DM details in a few so that it won’t be used otherwise. Will only be baby.
Muchas gracias, senor :slight_smile:
I just think out loud, and you guys start working on a script like Giant Amazonian ants (Dinoponera - Wikipedia). No script is really necessary. I just thought it might further remove some silly mistakes like forgetting to remove .safe and/or inputting some old version numbers. I’m not here to manage or pressure anybody. But thanks all the same!
If everyone is starting from the same commands then it removes a possible source of error/confusion.
So IMHO its entirely worthwhile.
Edit: The less time we waste on silly config errors and no-quite-right command lines, the more time we have to look for real problems
just to confirm here,
that command does not include nohup so closing the terminal kills the node.
as @bochaco said regular safe node join --skip-auto-port-forwarding
will work and directs logs also.
alternatively I think we need nohup or something along the lines of
nohup ~/.safe/node/sn_node --skip-auto-port-forwarding --log-dir ~/.safe/node/logs --json-logs &
OK as soon as I can get a connnection-info.config that works, I will try this out.
Certainly makes sense to me
There is also $ safe node install which pulls the latest version available of sn_node and installs it at ~/.safe/node/ ready to then be used by other CLI’s node commands. There is an issue at the moment which doesn’t allow to specify a specific version of sn_node but latest, although that’s being fixed as well for future use.
Thats disabled for now - sadly would have saved much faffing…
willie@gagarin:~$ safe node install
Error:
   0: Self updates are disabled
   sn_cli/src/operations/node.rs:73
…I see, ok, thanks!
This was unintentional. A PR I’m submitting shortly will fix it. I wanted to do all these testnets after we had better UX :).
It is extremely unfortunate that the command to copy from the terminal Ctrl-Shift-c is so similar to Ctrl-c
Also unfortunate is that my advice above about how to find the assigned port may not be correct in all circumstances – seems like it is caching an old port somehow despite me nujking ~/.safe on every run… Obv something simple Im missing…
Luckily the hour has just changed so I have a fresh log file to pore over
No shortage of eagerness to run tests. Better UX, good reason for more testing, just give us a reason :slightly_smiling_face:
Can you open the port and then set it with --public-address in the join command?
Not ideal for a script though.
Can you restart that baby-test Looks like its caching port 54705 for my IP
addr: 9n.nnn.nnn.nn5:54705, connection: None }
but then fails with
Node cannot join the network since it is not externally reachable: 9n.nnn.nn.nn5:33174
Mostly due to me ctrl-Cing instead of actually copying from the terminal
Unsure how I would (quickly) put that in a script…
Just a general comment: the node join command should expose the necessary arguments now.
