Yes im in both nodes on line just uploading the cock now
Test net cockerel
safe cat safe://hygoygyyb1aq95ugj4kyp98gz87px3d9becszpo1hbxmxwrgjfsg778rz88go > cockrel.jpg
BBS mp3
safe cat safe://hygyy1yybp9edeorgb1wyu9yyoofd9nuz3czc9339kx7gdcumq9fx8r6sj9ey > BegBlagSteal.mp3
Same, can’t connect and can’t download neik files either (timeout)
INFO 2021-12-19T15:47:59.556112Z [sn/src/routing/routing_api/mod.rs:L152]:
➤ d52e13… Bootstrapping a new node.
ERROR 2021-12-19T15:48:59.568941Z [/Users/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/qp2p-0.27.2/src/endpoint.rs:L290]:
➤ bootstrap {bootstrap_nodes=[64.227.38.26:12000, 64.227.46.69:12000, 64.227.46.71:12000, 64.227.46.81:12000, 64.227.46.88:12000, 64.227.46.94:12000, 64.227.46.95:12000, 64.227.46.98:12000, 64.227.46.105:12000, 64.227.46.119:12000, 64.227.46.129:12000, 64.227.46.137:12000, 64.227.46.173:12000, 64.227.46.175:12000, 64.227.46.185:12000, 165.22.114.140:12000, 167.172.55.48:12000, 167.172.55.224:12000, 206.189.119.11:12000, 209.97.142.51:12000]}
➤ Failed to bootstrap to the network, last error: timed out
WARN 2021-12-19T15:48:59.569495Z [/Users/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/qp2p-0.27.2/src/endpoint.rs:L418]:
➤ Could not determine better public IP than local IP (0.0.0.0)
WARN 2021-12-19T15:48:59.569519Z [/Users/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/qp2p-0.27.2/src/endpoint.rs:L443]:
➤ Could not determine better public port than local port (59938)
Error:
0: Cannot start node (log path: unknown). If this is the first node on the network pass the local address to be used using --first
1: Routing error:: Could not connect to any bootstrap contact
2: Could not connect to any bootstrap contact
sn/src/bin/sn_node.rs:223
for @Sascha
safe cat "safe://hyryyryynat7nqenbornfdmqrktitjihic8dbga44gnxu7mbket9kr9wioqgyeuy?v=hii4cmonukh1wbsrmz466yotst893okerpfm6z5es6eiapq1uhp9o"
did you rm -rf $HOME/.safe
and start from the beginning again ?
I killed all my nodes and ran
safe networks switch comnet again and it looks OK
that must be the smart way to do it im guessing safe networks switch comnet
clears all the old chunks ?
No it just ensures that the node is looking at the correct connection info.
You need to rm -rf ~/.safe/node/root_dir to clear the old chunks
haha must have subconsciously selected a good colour !!
I kept forgetting which SSH window was which so that was the solution a Celtic node
The cock works. (cockrel.jpg)
But the chickens aren’t talking. (chicken-talk.mp3) The file is there, but it doesn’t play.
another one for you
safe cat safe://hygoygyybyo4mn6imdpsoq1imq6x7nwikchpk4rrzt6gdfif5wf8mpngmhycy > whatyoulookingat.jpg
Trying hard to join the network. No luck so far!
RUST_LOG=safe_network=info,qp2p=info ~/.safe/node/sn_node --skip-auto-port-forwarding
Starting logging to stdout
INFO 2021-12-19T16:17:57.652328Z [sn/src/routing/routing_api/mod.rs:L152]:
➤ 343278… Bootstrapping a new node.
INFO 2021-12-19T16:17:57.810391Z [sn/src/routing/routing_api/mod.rs:L166]:
➤ 343278… Joining as a new node (PID: 25085) our socket: 93.9.80.102:64514, bootstrapper was: 159.65.52.30:12000, network’s genesis key: PublicKey(03a4…e396)
INFO 2021-12-19T16:17:57.812265Z [sn/src/routing/core/bootstrap/join.rs:L505]:
➤ join {network_genesis_key=PublicKey(03a4…e396) target_section_key=PublicKey(03a4…e396) recipients=[Peer { name: 343278(00110100)…, addr: 159.65.52.30:12000, connection: Some(Connection { id: 140555548059152, remote_address: 159.65.52.30:12000, … }) }]}
➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(03a4…e396), resource_proof_response: None, aggregated: None } recipients=[Peer { name: 343278(00110100)…, addr: 159.65.52.30:12000, connection: Some(Connection { id: 140555548059152, remote_address: 159.65.52.30:12000, … }) }] section_key=PublicKey(03a4…e396) should_backoff=false}
➤ Sending JoinRequest { section_key: PublicKey(03a4…e396), resource_proof_response: None, aggregated: None } to [Peer { name: 343278(00110100)…, addr: 159.65.52.30:12000, connection: Some(Connection { id: 140555548059152, remote_address: 159.65.52.30:12000, … }) }]
INFO 2021-12-19T16:17:57.935072Z [sn/src/routing/core/bootstrap/join.rs:L367]:
➤ Setting Node name to 6d4c04… (age 44)
INFO 2021-12-19T16:17:57.935101Z [sn/src/routing/core/bootstrap/join.rs:L374]:
➤ Newer Join response for us 6d4c04(01101101)…, SAP SectionAuthorityProvider { prefix: Prefix(), public_key_set: PublicKeySet { public_key: PublicKey(0373…7551), threshold: 4 }, elders: {Peer { name: 0d5374(00001101)…, addr: 167.172.57.225:12000, connection: None }, Peer { name: 340a7b(00110100)…, addr: 167.172.53.54:12000, connection: None }, Peer { name: 767610(01110110)…, addr: 167.172.49.98:12000, connection: None }, Peer { name: 76c2d6(01110110)…, addr: 167.71.131.135:12000, connection: None }, Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }} } from Peer { name: 5802ad(01011000)…, addr: 159.65.52.30:12000, connection: Some(Connection { id: 140555548059152, remote_address: 159.65.52.30:12000, … }) }
INFO 2021-12-19T16:17:58.302484Z [sn/src/routing/core/bootstrap/join.rs:L505]:
➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(0373…7551), resource_proof_response: None, aggregated: None } recipients=[Peer { name: 0d5374(00001101)…, addr: 167.172.57.225:12000, connection: None }, Peer { name: 340a7b(00110100)…, addr: 167.172.53.54:12000, connection: None }, Peer { name: 767610(01110110)…, addr: 167.172.49.98:12000, connection: None }, Peer { name: 76c2d6(01110110)…, addr: 167.71.131.135:12000, connection: None }, Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }] section_key=PublicKey(0373…7551) should_backoff=true}
➤ Sending JoinRequest { section_key: PublicKey(0373…7551), resource_proof_response: None, aggregated: None } to [Peer { name: 0d5374(00001101)…, addr: 167.172.57.225:12000, connection: None }, Peer { name: 340a7b(00110100)…, addr: 167.172.53.54:12000, connection: None }, Peer { name: 767610(01110110)…, addr: 167.172.49.98:12000, connection: None }, Peer { name: 76c2d6(01110110)…, addr: 167.71.131.135:12000, connection: None }, Peer { name: 8df9d1(10001101)…, addr: 167.172.62.117:12000, connection: None }, Peer { name: b4f7f5(10110100)…, addr: 167.172.61.82:12000, connection: None }, Peer { name: f431a3(11110100)…, addr: 167.172.53.134:12000, connection: None }]
ERROR 2021-12-19T16:18:58.383128Z [sn/src/routing/core/bootstrap/join.rs:L164]:
➤ Node cannot join the network since it is not externally reachable: 93.9.80.102:64514
Unfortunately we are unable to establish a connection to your machine (93.9.80.102:64514) either through a public IP address, or via IGD on your router. Please ensure that IGD is enabled on your router - if it is and you are still unable to add your node to the testnet, then skip adding a node for this testnet iteration. You can still use the testnet as a client, uploading and downloading content, etc. https://forum.autonomi.community/
Ok then I’ll just upload some (small) stuff ![]()
BegBlagSteal.mp3 works.
whatyoulookingat.jpg works (and looks pretty much exactly like one of my late chickens. I’ll PUT her here once I get around to it.).
dont give up
looks like you need to do a manual port forward on your router
see the line in the mesage you get when you start the node that reads ➤ 343278… Joining as a new node (PID: 25085) our socket: 93.9.80.102:64514, bootstrapper
so for that node you would have had to forward port 64514 on your router to the internal ip of your node
the port changes every time so start the node get the port and go straight into your router to do the port forward before it times out
whatyoulookingat.jpg has triggered me and brought back horrible memories I had repressed of one of my English teachers asking me just where my homework was.
Thanks for nothing @aatonnomicc
A small PUT worked for me. The picture is for @neo. I can’t find my identical chicken pick in a hurry.
sascha@sascha-Librem-15-v3:~/Downloads$ time safe files put Bread.jpg
FilesContainer created at: “safe://hyryyryynedjmw1wiu53s8ukuhobs7k7wunb1x74mfrk8dog9zxn9df5tubdyeuy?v=hhhqqqjf7qtzfqi3tz9bgq5ckaggbgsjn9nu86y5jcjckdh9u86uo”
- Bread.jpg safe://hygoygyyborsyr6mpzw3f6hx8jsfpkpj9c1pyrire4cocpzeinhgq18gy1xny
real 0m14,420s
user 0m2,917s
sys 0m1,406s
sascha@sascha-Librem-15-v3:~/Downloads$ time safe cat safe://hygoygyyborsyr6mpzw3f6hx8jsfpkpj9c1pyrire4cocpzeinhgq18gy1xny > bread-down.jpg
real 0m5,521s
user 0m1,948s
sys 0m1,040s
