Not sure if, beyond public test nets consistently releasing and succeeding, MAID will ever go much higher than this, so in my many years of experience with watching this token, it’s best to not panic buy until then. The other exception (and still don’t do it in a panic) is crypto funds overall finally spilling over from larger projects into this one—and somehow staying at a new floor decently above 10 cents—just from the sheer volume of trades increasing or what have you. Which of course could happen soon, though I think the latest BTC rise is because of the Silk Road situation, dunno.
Thanks for providing that visibility. I’m curious about two things:
- Can you say more about this? I suspect
Performancein context here should be okay, butData Consistency?
- Is the plan to eventually replace AT2 with DBCs? Otherwise, the fact that DBC doesn’t have
Verifiable Historyshouldn’t matter if it is based on AT2 and so gains that property through the latter, i.e., DBC-based money is only issued upon deposit of the same amount of AT2-based money.
A side project that @oetyng is working on uses some of AT2 to get consensus on DBC spending. So the client asks for the re-issue from the majority. It means true anonymity but zero verifiable history. This seems to be the trade-off we are seeing. What we are also looking at is some mechanism to prove coins cannot be created and max number is set. These parts are not so easy but potentially required.
There is a half way hous, so we say no coins are available until a point where we know many folks are involved in the network, elders belong to many different parties and then just decide, now coins are all available. It’s all side projects, but at the same time very interesting. I like the idea of DBC for privacy and efficiency (the client does most of the work and banks/mints do very little). It has great promise, but open to manipulation by the creators right now, fixing the latter part is a task we are working on. Lucky we have options there.
The community will be very important in probing this part as it’s likely we have a simple easy to understand method of anonymous cash so close.
Failing all that we have pure AT2 with blinded histories. It’s not a bad back stop.
None of this delays testnets though. DBC could transform the economics of the network in terms of efficiency and privacy. We will find out quickly though.
What I just said guys!
Looks like it’s still pumping.
Oh look, almost all top200 coins are!
Please pardon my ignorance of this issue.
Would you please define or point me to a definition of “Verifiable History”?
I think of DBCs like cash. More correctly like money, (intrinsic value as opposed to fiat fraud paper) but bear with me for sake of argument:
If I spend cash, it’s ‘anonymous’ by default. Nevertheless, with many merchants, I’ll have the option of a receipt. Extending the analogy to SAFE’s data permissions, the cash transaction is like private data, whereas adding a receipt creates a permanent record like public data. That’s not to say the receipt record would necessarily be public, only that the receipt record would exist at least in the user’s private wallet.
Could there be any benefit to DBCs with private/public optional transaction records, or does “Verifiable History” imply public and complete visibility of all transactions as bitcoin’s blockchain has?
Seems like a beast is awakening a bit, doesn’t it? I wonder how price reacts when we have a test net and MAID.erc20 ![]()
Look at daily not intraday on MAID, it’s too volatile, better to see the larger trend.
A stopped clock is right twice a day! ![]()
Forgive the jibe, but you’re never have the most positive outlook for MAID here.
Sorry, but I’m just realistic…
As all pessimists and optimists so believe ![]()
Old Dire straits line
“There’s 2 men on the corner say they’re Jesus, one of them must be wrong”
I am an optimist and I really want to have Safecoin so I don’t have to buy books with dollars hidden in a floppy disk ![]()
Good questions @anon57419684, and no need to apologize for asking or not knowing ![]()
The property I intend to describe is for any user to be able to cryptographically verify the integrity of the monetary system.
For example, with current AT2 system, all debits and credits could theoretically be traced back to the genesis. That is also the Achilles heel of the system, since logging Elders can map out a whole lot of transaction information.
I think so, definitely yes. There are many use cases for completely transparent finances.
It could. But it has not so far been the necessary implication, in my mind at least.
Yeah, sure. It’s actually just about the current implementation. It seems not terribly big of a deal to get data consistency in place there.
Edit: Sorry, maybe saying more would entail somewhat of an explanation… AT2 builds upon exchange of events, operations. When any party is out of synch and does not understand an incoming request, they could simply request any events not seen, which would bring them up to the required state to handle the request. This here is where we are currently not 100%. There seems to be edge cases where we do not get all parties up to speed. But it’s a relatively trivial problem to solve.
I think David laid it out well for point 2 there.
This is helpful. Appreciated
Re:traceability of pure AT2, I think at even after implementing AT2-DBC to gain anonymity it may be useful to keep pure AT2 as an ecological and performant “blockchain” that can be used for use cases where traceability/transparency is needed. It wouldn’t have safecoin’s monetary value of course, but rather some sort of transparent ledger service.
Price holding nicely after that pop/dump/pop back. It’s actually a real change from the months of stability around 0.1 USD even while other things popped. Still one of the best risk rewards in crypto ATM.
Por que no los dos? Could there not be an AT2 backbone, and a transaction type that would convert a safe balance into a DBC? (as well as a DBC transaction for an authorized spend to an AT2 balance?) E.g. for this portion of SAFE, want anonymity and need performance, so send the SAFE to a mint to get a DBC? And the mint would use a bulletproof on the minting transaction that would make creation of extra SAFE impossible?
There could be, but perhaps a bit more complex. We can use the digital secure broadcast from AT2 (we do actually, work is in progress with our CRDT guys).
Lots more happening, but great to see all these suggestions, it just makes us stronger and having more than 1 way to crack this is really comfortable.
That’s kind of how I imagine it working too if we want the best of both worlds. I’m wondering if there are other ways though. I don’t know how performant AT2 is but a recent comment from @oetyng perhaps suggests that regardless DBC would bring more to the table in the regards of performance and anonymity. But therein lies the crux of the issue because yes we want the best performance but we may not actually always want anonymity but rather a saved receipt that verifiably proves you made a specific payment to a specific ID or wallet. Now DBC would likely take more weight off the network and be preferred from a network/engineering standpoint but in practical terms would the general population use more of 1: AT2 (fallback/backbone) for online transactions w/receipts or 2: DBC for private and online/offline bearing?
While I agree there are use cases that don’t require full anonymity, or any at all, I feel this is a bit like with comms/data in general. In all being secure and anonymous, everyone is protected. Separating out less protected parts decreases protection for everyone. But that’s naturally a very general and high level view and there might be plenty of combinations/variations that provide enough of what we need of the various aspects. Just wanted to mention it.
@oetyng
Right. So who’s to say we don’t just have full anonymity with DBC and then someone (maybe Maidsafe or other) comes along and makes a second layer solution that is another cryptographic/provable way but using your SafeID and sending a DBC so that the info is either public or has a receipt? I’m assuming that could be possible. Kind of like some verifiable wrapped transaction where transparency is the feature. Like using cash at a store but still being handed a receipt. Less mucking about with lessening full anonymity of the underlying network. Thoughts?
