People could farm with smart phones.
Also, my understanding is that your data won’t be persistently cached locally … but if the future means small devices with massive storage capacity, maybe it should be?
Yep. I daresay that this is among Dawn’s plans for hardware using Maidsafe. Basic concept: Put far better antennas in devices than manufacturers normally do. Then, use two separate radios. It is possible to do two wi-fi networks with one radio, but tends to flail about and die frequently, or do other strange things, so we’ll spend the extra few bucks and simply use two separate radios.
(probably should read: Imagine: what if smart phones had a 1TB SSD in them)
well said.
