How to withdraw maidsafecoin from paper wallet?
Hi, sorry am kind of a newbie here. But i have totally no idea how to send the maidsafecoins from my paper wallet ( generated from bitaddress) to another address. How do i do this?
Thanks!
One way is to
  • make sure you have some bitcoin in the address
  • create a wallet at omniwallet.org
  • make sure you remember the credentials
  • import the private address (starts with β€œ5”) that bitaddress gave you into the wallet
  • then you can send your funds (the site will tell you how much bitcoin is needed for the fees) NOTE: the bitcoin must be in the same address that the MAID is in
Ok thanks. Very clear. Will try out
Oh, another thought, if you have some MAID left and don’t want to send them anywhere for a while then it might be wise to make another paper wallet address and send the remaining MAID there along with enough BTC to move them later on
Oh ok, will do, thanks.
