Hello there, I put some Maidsafecoins in my blockchain.info a long time ago and now I’m trying to figure out how to transfer them out. With all the changes they’ve made over the years does anyone know what the most updated method of doing it is? Thanks in advance.
Try using omniwallet.org to see your balance using the public address.
Then do you have the private key to your address? If you do then you can create a omniwallet.org wallet and import the private key into it and then send your coins where ever you want.
I could not find where the private keys are stored in my blockchain.com account but I found this set of instructions on how to export it
Exporting Private Key from Blockchain.info and Importing to Omniwallet.org · OmniLayer/omniwallet Wiki · GitHub
This was written a year ago though and the instructions are fairly complicated. Can anyone confirm if this still works? Thanks
