Yep it’s working - I haven’t tried a video yet.
Was trying to get something ready for work tomorrow. Oh well, mañana
Probably but it the vein of not wanting to store everything I was thinking of perhaps having a save option.
No worries, I hadn’t quite understood what you were doing. Videos (mp4, mpg) download but don’t open on my Mint system.
tauri seems neet but all the documentation has errors like using ’ for strings and rust is against that today… anyhow, anyone knows how I can run powershell commands with tauri?
it was the js code, but I still cannot make sense how to run powershell commands with tauri… anyone can help me?
I startpaged last night but got few hits and none that actually were useful
Upload and view work but the bottom row buttons don’t seem to do anything. (I’m using this version and already have baby fleming running) .
BTW I think the selector button should say ‘Select file’ as you can only pick one at a time.
Sorry, didn’t mean to confuse. I have not pushed all the changes to github yet. Will post here once it is fully updated.
You are correct!
managed to do it, tauri is aimed at npm peeps and someone on discord gave me the solution!
going forward slowly!
the positive is that safe commands run nice!
Am I being a dunce, should ls show all files in the container?
josh@pc1:~$ safe files put -r ./upload/10mb
FilesContainer created at: "safe://hyryyryumyk6winmfjpjjnzsw1s5xbedu7yigk5ikgfafym9qjqnjy39khanra?v=htd8ekp8g3yckaophy3u8exbh9kdhikaac74iwws46747fyc8c8py"
| + | ./upload/10mb | |
| + | ./upload/10mb/1.jpeg | safe://hygoygycjy3o7pihw94ag7dcxnjt77c7giu8m6rkawj6ayzenq49j1ug43o |
| + | ./upload/10mb/2.jpg | safe://hygoygye9kmehn4tr7yd1zocgsc8od7i3jk51rkyms97d4584kukujn47cr |
| + | ./upload/10mb/5mb.mp4 | safe://hy8ayqycoodiik3hxxyh5e635w4ueodu69fcwc6i86ooe9hnhm13jd7t4yo |
| + | ./upload/10mb/BlackMarble.tif | safe://hygoycyj4ka9r979tqwa37ikkfkjpnkp9ukpiedofkgphpgsxucqhzu9bsc |
| + | ./upload/10mb/keepswimming.jpg | safe://hygoygyxum8fhprm7fr615be1ej7c958sbk8ag66tpzczgy9non5ouwui6e |
| + | ./upload/10mb/min.jpg | safe://hygoygykfw5mtfyz7a783qfgregygwa3ur388qsnndron4ygnfqfijj6x8r |
| + | ./upload/10mb/pexels.mp4 | safe://hy8ayqyce9zc3smstq8d6mj7kzppjb963ci3y8czwten4td7etw4uitz67h |
| + | ./upload/10mb/spiral.gif | safe://hygoynyxgamgqbej7jhwinjaatdm1tm61hbz46pwwfrnuf6zxsm638nx3kw |
josh@pc1:~$ safe files ls safe://hyryyryumyk6winmfjpjjnzsw1s5xbedu7yigk5ikgfafym9qjqnjy39khanra?v=htd8ekp8g3yckaophy3u8exbh9kdhikaac74iwws46747fyc8c8py
Files of FilesContainer (version htd8ekp8g3yckaophy3u8exbh9kdhikaac74iwws46747fyc8c8py) at "safe://hyryyryumyk6winmfjpjjnzsw1s5xbedu7yigk5ikgfafym9qjqnjy39khanra?v=htd8ekp8g3yckaophy3u8exbh9kdhikaac74iwws46747fyc8c8py":
Files: 0 Size: 0 Total Files: 8 Total Size: 24000933
| SIZE | CREATED | MODIFIED | NAME |
| 24000933 | 1675978644 | 1675978644 | 10mb/ |
It works for me. On latest build
hmm, if you have a minute git clone --branch fixes https://github.com/joshclsn/Gooey will give you the most up to date version.
I mean running safe files ls <container-addr> works. I haven’t tried with gooey. I’ll give that one a go though, see what happens. Bear with me a sec
awesome thanks, I know it is possible to see the contents individual xorurl’s too but damned if i remember how… do you?
can you scroll down to see the rest?
you can for testing purposes, add the name of network that you would like to join in the text box and hit Join Network for instance feb2 should add successfully (but can’t use it) because the config is still there, you can also try comnet ![]()
Yep - I don’t know if ls shows the xorurls though
Mum’s the word…
might be buggy, I am running an old node version on there, and you have latest safe. dunno how that is going to go!
Yeah I can’t seem to PUT
eh, let me see if latest works… give me 10.
@JPL latest is not starting for me, idk why. hence I was using an old version. sorry
