EVM Testing for Beta Phase 2 Begins!
I don’t understand the question (?)
Maybe I’m missing something then! Maybe it’s not an issue at all. But this is what seems odd to me:-
0.000000008 = the cost to upload a minimally sized file.
0.000000000000000001 = what nodes are being paid.
0.000000000000000003 = what is being paid to nodes because 3 encrypted chunks.
0.000000000000000001 = for the datamap.
0.000000000000000004 = in total
Where is the rest of the upload cost going?
Yeah this is odd, this should be 0.000000000000000001
Nowhere - the number spit out by the cost estimator is simply wrong
1 atto per tb? :wink:
Ok! Fairy nuff!
Don’t start that again :man_facepalming:t3:
Exactly the Network’s growth comes before everything, it should not take a hundred years to upload the Internet Archive or 2.5 year @ 10 gb upload speed
https://www.airband.co.uk/fastest-internet-in-the-world/#1
1 attos for 1 DNS
1 attos for 1 altANT tx
1 attos for 1 TB
For starters, we are not here because we want to see clearnet persist
At least you’re consistent =) but without zero fees we’re far away from your dreams anyway :sweat_smile: :face_with_monocle:
Hey guys, I just want to check that I have out my address is correctly. When I run ‘safenode-manager status --details’ I see that there is a ‘-’ next to Owner. Is this correct? I feel like this should be where my wallet address should be?
Thanks
You are fine. it is a relic
thanks! I’ll just wait patiently for my attos then…
Make sure you check on the explorer, select ANT under “Token Holdings” Dropdown. It only shows after a certain amount on metamask, not sure what that number is.
(I have several hundred and it still shows 0 on metamask)
Sorry what is the explorer? Is that Arbiscan?
yes, https://sepolia.arbiscan.io/
Legend. 0.000000000000000053 earned :slight_smile:
vdash users please note…
vdash is not yet able to show earnings in attos so you will need to check your wallet balance instead. Apparently MetaMask isn’t showing attos either! So you will need to look up your ‘Token Holdings’ after entering your wallet address in the block explorer. If you see peers, records and storecost values in vdash that’s a good sign, so don’t worry that the attos don’t show up there yet.
I think someone said metamask shows the attos on hover
But the block explorer is the better solution for watching I guess
I read that too and neither of us managed to find it!
Metamask is showing attos. But it’s such a long trek behind the decimal point it is rounding it down to 0 in the main display and you have to to go to Details and then scroll right:-
