For anyone wishing to quickly build and test the code I have created a docker instance of a full build environment. You can install docker on many systems http://docs.docker.com You can find the maidsafe dev container here Docker Hub
This is a test to allow devs to quickly get a build environment going. We can also release docker instances of farmers for those who wish greater process separation from their own system. I do not think there is much need for this, but I figured this option was one some people may wish to pursue.
Be aware the dev image is pretty large ~1.9Gb, the release image would likely be ~300Mb.
For those on debian/ubuntu here is a quick script/set of commands to get a build environment locally to. Itâs pretty much all in the wiki, but this will get you a clang++ enabled build env quickly. This may help for the impatient (like me). If you issue these commands in this order then you are set.
What I havenât quite figured yet, is how to take advantage of CDNâs âŠmaybe itâs not possible⊠ie you donât get direct access to the disk I think.
You can set docker containers to access the disk if you wish (recommended for farmers). We just need to make sure that access is restricted, which is pretty simple.
Yes that would be possible. I am not sure how valuable it would be though, but I have not thought to much of it really. All the network cares about is getting the data from the vault, regardless of where it is, so should be cool.
I get this on the 2nd run of git submodule update --init using Ubuntu 14.04:
Cloning into 'src/api'...
Warning: Permanently added the RSA host key for IP address '192.30.252.129' to the list of known hosts.
Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Clone of 'git@github.com:maidsafe/MaidSafe-API' into submodule path 'src/api' failed
Looks like you do not have a github account with your uploaded ssh key there. I wish they did not require this. I think I will write a wee script that changes this over on the fly if required, makes it read only though so no commits In fact @Ross has a sed line somewhere that will do it. Its windy here so he is likely out wind surfing like a mad person
sed -i 's/git@github.com:/https:\/\/github.com\//' .gitmodules git submodule update --init --recursive
instead of the git submodule update --init
should work I will give this a try later on or @janitor you can let me know if this works
-- Detecting CXX compiler ABI info - done
-- No build type given. Setting and caching CMAKE_BUILD_TYPE to Debug.
CMake Error at CMakeLists.txt:94 (message):
The git submodule for common is not intialised. Please cd to
/home/dev/MaidSafe and run:
Can someone try this on fresh U14.04 and post the entire working script sometime this or next week?
Just to re-enforce there seem to be issues with this script - I tried it on a fresh LMDE install but have not looked into the failure yet. Not the git one, but the last one @janitor reports looks familiar. Iâve swapped drives back to running Windows in this machine now (trying to track a recent system freeze) so canât look into it atm.
Yeah it doesnât work. I tried to re-run and now I also get the same public key error in the modified line after sed command:
I get the error on the first run on this command too. Do the both instances of the failed command have to be replaced with the sed line and git submodule update command that follows?
I tried to delete checked out source code tree but Iâm not sure if that is enough of a reset or not.
It really should be verified using a fresh install without any preexisting SSH keys or things of that nature.
Back to booting LMDE until the next system freeze⊠so:
Is this line correct?
The error in bootstrap.log is âclang not foundâ.
I tried:
CXX=clang++-3.4; CC=clang-3.4; cmake ../
but this doesnât change the error. Echo $CC gives clang-3.4 so âŠ?
EDIT: @dirvine I see from my earlier captured output that the above line is correct, cos âcmakeâ happily reports clang-3.4 etc. So for some reason the make in boost is not seeing this I think. Are you using a special shell, or is there some way these values are not getting passed on (maybe you have them defined elsewhere on your system and the above is not adequate?).
EDIT: Also, since I ran this my package manage has been complaining about âŠ
Failed to fetch http://ppa.launchpad.net/andykimpe/cmake/ubuntu/dists/testing/main/source/Sources 404 Not Found
Failed to fetch http://ppa.launchpad.net/andykimpe/cmake/ubuntu/dists/testing/main/binary-amd64/Packages 404 Not Found
Failed to fetch http://ppa.launchpad.net/andykimpe/cmake/ubuntu/dists/testing/main/binary-i386/Packages 404 Not Found
Failed to fetch http://ppa.launchpad.net/ubuntu-toolchain-r/ppa/ubuntu/dists/testing/main/source/Sources 404 Not Found
Failed to fetch http://ppa.launchpad.net/ubuntu-toolchain-r/ppa/ubuntu/dists/testing/main/binary-amd64/Packages 404 Not Found
Failed to fetch http://ppa.launchpad.net/ubuntu-toolchain-r/ppa/ubuntu/dists/testing/main/binary-i386/Packages 404 Not Found
Some index files failed to download. They have been ignored, or old ones used instead.
I use Github to check out stuff every week, but the instructions must be correct for this to work.
If you arenât familiar with the source code, which part does what and whereâs what, itâs difficult to figure it out on your own.
The devs supposedly use this every day so it shouldnât be a big time consumer for them.
The github issue is just a matter of setting up the private key on your github account - follow github online help and it works fine - let me know if you canât get it working. Obv the script can be improved to avoid the need for this.
The issue I was referring to is make falling over.
I havenât attempted that because I donât think thatâs how itâs supposed to work.
Is every beta tester (hopefully hundreds of people) supposed to create a beta account and upload his keys to Github?
I have a Github account and use several projects and have never needed to do this.
No, it isnât necessary but it will enable you to proceed. So its a way forward if you want to go forward. If you search the forum, you might find a previous time where David showed someone how to do this, or you can just configure your github ssh key and go. Just trying to help man.
I know and appreciate that. I just wanted to say it should be made easier if we want to get as many testers as possible. These errors are developer level errors and can hardly be fixed by mere testers.
Hopefully weâll get updated instructions later this week.
