People,
I haven’t done much C++ in a while (and I was never that competent anyway) but I know enough to get into trouble - maybe there is some stuff that I could do like testing and maybe help track down a bug or two?
Regards,
Phil.
People,
Regards,
Phil.
Jump in Phil, you can work away at the common lib as a start and perhaps look at coverage and improving it. That is a good start to get comfy.
dirvine,
That was quick! - so maidsafe/MaidSafe on gitHub?
Thanks,
Phil.
Yes If you follow the build instructions Home · maidsafe-archive/MaidSafe Wiki · GitHub for your platform it should build pretty easily.
OK, I see there is Ubuntu and ArchLinux listed so far - I will let you know how I go with Fedora (v20).
Regards,
Phil.
