Where can I keep my coins for Maidsafe? currently, they are in BITTREX
Where can I keep my coins for Maidsafe? currently, they are in BITTREX.
Please help, I am new in this crpytocurrency. Which wallet I need to set up?
Hi Trini welcome to the cryptospace, :stuck_out_tongue:
{update} Wow your lucky today I was not lazy, so I made a video.
I did forget something enabling 2FA, go to the top right menu “My account” “Account Settings” “MFA”
You can follow these steps
But three important things when you create a omniwallet.org account
  1. write down your omniwallet walletID + password (if you don’t YOU LOOSE ALL YOUR MONEY, if you don’t have your privatekey)
  2. write down your privatekey see in the video how it’s done. Overwrite the file you download and delete it after you got your privatekey.
  3. enable two factor authentication
If something is not clear our you need help just ask.
Cheers
thank you 19eddyjohn75. so helpful. :slight_smile:
I said thank you without viewing your video…however when I play your video, there’s no sound of your video. can you relaod with sound. thanks again.
