I opened a github issue and linked this topic ![]()
I assume this behavior is of interest to some other people too
Thank you for opening the error in github issue
When I say that sometimes, not all�
I canât see my maid
is the other error that appears in github
I hope that these exposed problems will help to solve the problem.
SECURITY NOTICE!
I donât think anyone here will make this mistake, but weâd better warn.
Hey all â creator of omnitrezor.com here. First I would like to say Iâm really glad people are getting some use out of the tool and that it has passed the initial community teardown (mostly)
. Second, I am very sorry about the issue mentioned above where the amount sent was different than the amount entered, I will check this out first thing in the morning and report back.
Regarding the wallets sometimes showing up and sometimes not, that particular part of the app was a bit tricky. The way the OMNI protocol works, it was easiest (and safest) to put in place some basic enforcements before a transaction was attempted - most notably that there is a single output on the wallet greater than 800 satoshi, which is different than the wallet itself having total outputs (the balance shown in Trezor) greater than 800 satoshi. Open to suggestions and pull requests here â maybe we can show in an expandable menu wallets that have OMNI tokens but that donât meet the proper requirements for a transaction, with some explanation? And if itâs being sporadic, itâs possible the issues are on omniexplorerâs side, whose API is used by the omnitrezor tool.
General suggestions for improvement are also most welcome. Probably the best place to get support and request features would be on the projectâs Github page: GitHub - tektite-software/omni-trezor: OMNI Wallet for Trezor. I will do me best to respond to issues there in a timely fashion as the quality and correctness of this application ultimately reflects back on me and my organization.
Ok, so yes I did see there was a bug where the amount field was not always in the proper format before being hex-encoded, which resulted in it not being encoded properly. It should be fixed now. On the âSign & Sendâ screen, I would also like to mention if you click âShow OP_RETURN Detailsâ youâll be able to see the full encoded OP_RETURN data with a brief explanation of each part. Itâs probably unreasonable to expect every single user to understand that, but I definitely encourage double checking that before you send. I do see that as of the latest firmware the Trezor screen itself does display a confirmation correctly. Going to close the corresponding issue on GitHub. Thanks!
OK, so I guess this is stable to transfer maid from paperwallets nowâŚ
Is omniwallet.org working? Iâm trying to create an account to import my paperwallet (and later on send it to the trezor address), and it says âserver errorâ. Also checking the balance does not work (stays in âloadingâ for ever).
A couple of times I couldnât even open the website, so I guess the hosting must be having problems and will try later on, but would be nice if someone could confirm.
Are u using chrome?
It dislikes some browsers.
Chrome is reccomended @raulillo
Loads well to the landing screen on my phone.
I got my Trezor wallet yesterday and tested it. Works stably with MAID. Iâll post a guide these days soonâŚ
Even with Chrome, omniwallet.org is not stable. I get 502 http errors from time to time when logging in. I did manage to log in into my wallet (not so important as itâs empty and my maids are in a paperwallet), but checking the balance of the paperwallet stays in loading. Is it working for you guys?
I donât dare import the private key if itâs so unstable right nowâŚ
I so want a hardware wallet, but the stories of people being sold them with them already being compromised scares me away.
To be honest, Iâve not moved coins for a long time with omniwallet, used to be buggy for me also, having to log out then back in to complete the transfer, but it always worked in the end.
Good luck!
Yes, buggy as hell. Can anyone check any maid address with the balance check tool and see if it works? I did import my wallet with the private key, but shows as empty.
If you buy directly from the manufacturer I donât think itâs a problem. They come sealed with holographic bands. They also have no pre-installed firmware ie. completely empty with no generated addresses in them âŚ
OK, glad to see itâs not only me then. I did send an email to their support and they opened a ticket. Hopefully will be fixed somewhen.
Thanks for confirmation, it was a relief. Letâs wait.
you can use https://omniexplorer.info/ to check your balance
OK, I can see my maid there (and the little bit of BTC needed for the transfer). Another big relief.
As said, letâs wait for omniwallet to fix their endâŚ
Or take control yourself and run Omni Core
Any documentation about it? I did download the tool (apparently from omnilayer.org) and I can execute the binary in my OS. Thereâs no mention to MAID at all and I donât find how to import a private keyâŚ
OK, they fixed it. Already sent my MAID to my trezor, letâs wait for transaction to go throughâŚ
Thanks everyone!
Edit: After a bit of fighting to get in the trezor address at least 8000 satoshis, I can see the maids in my trezor account. Great job, and thanks again!
