ThisIsNotBetaRewardsNet [Mini-Testnet 26/05/24] [Offline]
@joshuef Here is that “stretch rewards” after about 5 hours (started nodes about 20 minutes after OP) For the nodes started with the launcher
Also I have to note that the error rate (on the device started with the launcher - starlink) at the beginning was very high compared to previous betanet using --home-network. Like 20 times higher than beta net after only 10 minutes in the many thousands. After 5 hours it seems to have improved with it being 17,000 to 30,000 on the 30 nodes on starlink
safenode14/logs/safenode.log:225
safenode3/logs/safenode.log.20240526T135836:287
safenode3/logs/safenode.log:43
safenode13/logs/safenode.log:201
safenode6/logs/safenode.log:159
safenode2/logs/safenode.log:99
safenode29/logs/safenode.log:181
safenode2/logs/safenode.log.20240526T134043:743
safenode20/logs/safenode.log.20240526T134334:317
safenode20/logs/safenode.log:80
safenode21/logs/safenode.log.20240526T133537:318
safenode21/logs/safenode.log:117
safenode12/logs/safenode.log:200
safenode5/logs/safenode.log:295
safenode25/logs/safenode.log.20240526T125338:428
safenode25/logs/safenode.log:249
safenode24/logs/safenode.log:3
safenode24/logs/safenode.log.20240526T143001:201
safenode10/logs/safenode.log.20240526T135007:1071
safenode10/logs/safenode.log:50
safenode23/logs/safenode.log.20240526T151145:165
safenode8/logs/safenode.log:788
safenode4/logs/safenode.log:199
safenode7/logs/safenode.log:199
safenode15/logs/safenode.log.20240526T151231:285
safenode26/logs/safenode.log:200
safenode11/logs/safenode.log:205
safenode1/logs/safenode.log:192
safenode17/logs/safenode.log.20240526T143317:403
safenode17/logs/safenode.log:4
safenode18/logs/safenode.log.20240526T133428:200
safenode9/logs/safenode.log:159
safenode18/logs/safenode.log:124
safenode16/logs/safenode.log:145
safenode27/logs/safenode.log:174
safenode28/logs/safenode.log:3
safenode22/logs/safenode.log.20240526T140609:249
safenode22/logs/safenode.log:28
safenode28/logs/safenode.log.20240526T145233:250
safenode30/logs/safenode.log:169
safenode19/logs/safenode.log:4
safenode19/logs/safenode.log.20240526T143133:258
9670 matches
9670 matched lines
42 files contained matches
11309 files searched
0 bytes printed
685417390 bytes searched
8.558697 seconds spent searching
2.291509 seconds
I had SAFE_PEERSs set to the list @aatonnomicc posted for the comnet. I doubt that would have helped…
Can I get some fresh SAFE_PEERS please?
@Southside
/ip4/95.217.215.234/udp/56118/quic-v1/p2p/12D3KooWB4mp4NZc4dHN6zJSNRMGHLh75xAhia8gtAiqQqbHRTjM
/ip4/37.27.21.73/udp/44328/quic-v1/p2p/12D3KooWRZirEhdGrGZe9v9GHNXyTzJPt2SnoJSKXoYsXNAACQLK
Thanks for the peers, lunching 16 nodes (8 peer 1, 8 peer 2) with home-netwrork. Will lunch within few hours 60 of them from vps.
Discord username: r433803
once the launchpad is downloaded how do i launch/run it?
Fast uploads to network and working :smiley:
Nodes working now. :tada: How do I get rid of inactive ‘added’ nodes from the display? Ctl-X doesn’t do anything and ps aux | grep safenode doesn’t find any services named safenode1 or safenode2.
After extracting it from the zip file, run ./node-launchpad from the folder you extracted it to.
On Linux laptop:
unzip node-launchpad-0.2.0-x86_64-unknown-linux-musl.zip
./node-launchpad
I simply did another ctrl+g and they started
Didn’t work for me. I had to do O then add some more storage space, then ctl-g started two new nodes.
That is why they need to (at some stage) add progress info and status as to success/failure reasons
very cool :slight_smile:
…but tbh it’s not 100% intuitive yet … tried to set my discord name with [capital] D … didn’t work … wanted to set resources with [capital] O … didn’t work either … i did recognize it’s non-capital letters … but for starting nodes it’s correctly shown … (and yes nano does this too … but i think it’s misleading there too …)
i don’t see how i can remove single nodes again (because my internet speed is a bit limited … just wanted to test adding a couple and now they’re there :open_mouth: …)
same here - per 5gb it’s possible to add one node?
maybe i should have done it in a VM xD …
2 nodes running! :dragon:
discord username: dimitarsafenetworkbulgaria
Which ports should I forward for a better connection?
This is a good question for the launcher, how does the launcher decide which mode to use for connection and how can we find out @joshuef
I want to use port forwarding and not uPnP, but cannot see how to make the launcher use port forwarding and the ports to use.
@Dimitar I am guessing that the launcher tries uPnP and if that doesn’t work then home-network. I doubt it will do port forwarding since that is more a expert user who is likely to use node-manager or run the nodes directly and will port forward that way. So there is no point in adding port forwarding to the router if using the launcher
If you run safenode-manager then good to start with port 12000 or start above that
There will be no faucet for the beta… faucet remains just for this mini test.
And if I got it right, you said previously the only way to get tokens is earning them. And later on the conversion testing from omni maid
Now is that earning from nodes not participating in the beta program or have you worked out how we can keep them to use for uploading
I’ll try it shortly but another point is that Ctrl- is not intuitive either. Dare I point to vdash?
If this is for ordinary folk it needs to avoid Ctrl or other combinations, and not set traps. Those menus in JPL’s screen shot cry out for people to try clicking them, and will confuse the hell out of users who don’t use the terminal. (At first I thought they were part of the launchpad UI because I don’t have that in my terminals.)
Testing it on us is also not a great way to find out how useable this is for non technicals so I hope ordinary folk are being included to weed out less obvious barriers.
As a regular Windows user I had to run the launchpad as administrator to get the nodes to work, this is not described in the OP.
Yeah, you can run nodes and not have them sending nanos in for rewards, and just have them for uploads.
Just think of it like the live network. Earn to spend on data, or “off-ramp” them for rewards.
How are would we keep them? Once the discord name is put in I don’t really see a way back? (oh well I guess it’s a bit of a work in progress)
