Hi !
I have a fresh built of sn_node and sn_api but things do not go welll when I test,
here are the version of the binaries, then the command I use and the result :
sn_cli 0.18.0
sn_node 0.26.11
sn_authd 0.1.0
safe mode run-baby-fleming --testing
Creating '/home/richard/.safe/node/baby-fleming-nodes' folder
Storing nodes' generated data at /home/richard/.safe/node/baby-fleming-nodes
Launching local Safe network...
Launching with node executable from: /home/richard/.safe/node/sn_node
Version: sn_node 0.26.11
Network size: 11 nodes
Launching genesis node (#1)...
Connection info directory: "/home/richard/.safe/node/node_connection_info.config"
Genesis node contact info: [[
"127.0.0.1:12000"
Common node args for launching the network: ["-vv", "--idle-timeout-msec", "5500", "--keep-alive-interval-msec", "4000", "--local"]
No RUST_LOG override provided
Launching node #2...
error: Invalid value for '--hard-coded-contacts <hard-coded-contacts>': invalid type: sequence, expected socket address at line 1 column 1
Launching node #3...
Launching node #4...
Launching node #5...
Launching node #6...
Launching node #7...
Launching node #8...
Launching node #9...
Launching node #10...
Launching node #11...
Done!
Setting up authenticator against local Safe network...
[2021-02-12T20:08:31Z DEBUG sn_api::api::authd_client::authd_client_api] Creating new authd client for endpoint https://localhost:33000
[2021-02-12T20:08:31Z DEBUG sn_api::api::authd_client::authd_client_api] Attempting to start authd from '/home/richard/.safe/authd/sn_authd' ...
Starting SAFE Authenticator daemon (sn_authd)...
sn_authd started (PID: 31275)
[2021-02-12T20:08:32Z TRACE sn_api::api::authd_client::authd_client_api] SafeAuthdClient instance being dropped...
[2021-02-12T20:08:36Z DEBUG sn_api::api::authd_client::authd_client_api] Creating new authd client for endpoint https://localhost:33000
Sending request to authd to create a Safe...
[2021-02-12T20:08:36Z DEBUG sn_api::api::authd_client::authd_client_api] Attempting to create a Safe using remote authd...
[2021-02-12T20:08:36Z INFO sn_api::api::common] Sending 'create' request to SAFE Authenticator on https://localhost:33000 ...
[2021-02-12T20:08:36Z TRACE sn_api::api::authd_client::authd_client_api] SafeAuthdClient instance being dropped...
Error: AuthdError: ClientError: No nodes/peers found defined for bootstrapping
richard@bombadil:~/safenet$ [2021-02-12T20:08:41Z DEBUG sn_api::api::authd_client::authd_client_api] Creating new authd client for endpoint https://localhost:33000
Sending action request to authd to unlock the Safe...
[2021-02-12T20:08:41Z DEBUG sn_api::api::authd_client::authd_client_api] Attempting to unlock a Safe on remote authd...
[2021-02-12T20:08:41Z INFO sn_api::api::common] Sending 'unlock' request to SAFE Authenticator on https://localhost:33000 ...
[2021-02-12T20:08:41Z TRACE sn_api::api::authd_client::authd_client_api] SafeAuthdClient instance being dropped...
Any help would be appreciated !
Richard
