For now think your best bet is sn_node 0.32.0 and latest cli. safe node install installs latest.
Looks like completing the merge of api and cli to safe_network is not far off, may be better to wait until then.
I’m trying to but progress is slow as I am in hospital wth severe gastro-enteritis and Im easy confused right now. @Sascha 's chickens have had their revenge as it seems most likely handling raw chicken was the culprit. The rest of the family who ate my lovingly-prepared and cooked chicken were fine…
The world has fallen out of my bottom.
Anyhow it seems to start fine if you specify --nodes 11 <–other values may work too - haven’t tried
Files put is failing for me but I’ll worry about that later - its writing logs so I can work with that.
