Here is an explainer video of the NAT hole punching and also about why it doesn’t always work:
00:00 - 08:17 How simple it used to be way back when.
08:17 - 12:40 Why UDP hole punching is nececcary, and hot it works.
12:40 - 16:51 Why it doesn’t always work.
I cannot evaluate how correct all that is, but seems legit to me. So, @anon26713768 it might work, if your router is not enforcing symmetric NAT, I guess.
symmetric NAT is a nightmare. Some allocate the next port on next connection and some use random next ports. Then if you have one on each side you are really in trouble. There are ways where you create over 10,000 connections to try. But in reality, it’s just hell.
That’s what I thought, but others seem to thing having a local IP different from the public/external IP is the problem.
Frankly I can’t see why that would be a problem. Webservers, torrents, all sort of services work this way: if you have a static IP, and correct ports forwarded, the router takes the request addressed to the external IP and routes it to the device indicated by the forwarding rule, and vice versa.
Why would safe be any different?
Torrent nodes can happily be uncontactable and maybe even relay via torrent servers. For Safe, we have no such servers as you need to trust them. So it’s a bit more nuanced, but a participating node must be contactable, either directly or by some other means. We don’t, as of yet, have another means of ensuring this connectability.
Am I correct to assume that if you’re using a VPN proxy, then NAT problems go away?
If so, then the solution here might be to implement relay nodes on SN … where the relays need to have VPN or otherwise solid connectability.
Not sure what would take longer to implement well nor what the tradeoffs might be, but having the option to use a relay if NAT traversal isn’t working for you seems a good option to enable S-A-F-‘E’.
I think that there is the future possibility of many different types of sub-nodes doing specialty tasks - like oracle work on the network. So enabling as many people to do node work in some capacity on the network is really important … longer run we’ll have IPv6, so maybe this isn’t a big concern … but who knows how long that will be. I don’t know the many and various tradeoffs so I can’t speak to the best “port forward” here … lol, sorry for the pun.
VPN is only a tunnel from point A to B, communication in the tunnel can be configured in countless ways. If the VPN provider gives public IP addresses in the tunnel than yes, it is a way to avoid NAT problems.
Just a FYI to anyone who has Frontier fiber in the US.
It is currently cheaper to switch from a standard home connection to a business connection.
You can regrade your line.
Your monthly subscription will likey be less for the same speeds.
Which makes up for adding additional IP’s.
1 static for 19.99 or 5 for 25.99.
New free wifi 6e router.
No install or switching fees.
No contract.
From the laptop look at https://www.whatismyip.com/
If it shows same IP address as you have on the laptop, then the laptop has public IP and you are fine (no NAT).
