Safenode program built from current github will not join the network (got the keys from logs)
@joshuef @chriso
I built successfully the safenode program, but when running it the nodes get 25 peers and no chunks and nothing else.
It gets 25 peers which I assume are the contact peers, but no more peers and no chunks etc.
The keys were obtained from the logs of nodes running the official binary.
Even tried setting SAFE_PEERS to one of the network contact peers to make sure there wasn’t some issue there in the build process. In this case I just get 1 peer is connects to
Used the build command line shown in github
cargo build --release --features=network-contacts --bin safenode
On the same machine, same terminal session the released safenode works fine.
Any ideas
are you building from stable?
Sounds like a protocol issue, and likely arising from a libp2p update which was breaking. I’m not 100% sure if this is in the prod code now.
But what is up should be what is in stable. (cc @chriso in case im wrong here!)
Built this from GitHub - maidsafe/safe_network: Autonomi combines the spare capacity of everyday devices to form a new, autonomous, data and communications layer of the Internet with the code taken not long after release
try from here: GitHub - maidsafe/safe_network at stable
Ah I was taking it from main.
Will try that, thank you. Yea I am new to github LOL after all these years using cvs never used github
@joshuef Update on this. Yes that solved my issue and I learned more today
