Well that is too obvious Chris, old dog new tricks and all that
wyse3@wyse3:/var/log/safenode/safenode2$ cat safenode.log
[2024-02-21T16:56:38.874943Z INFO sn_peers_acquisition] Using peers supplied with the --peer argument(s) or SAFE_PEERS
[2024-02-21T16:56:38.875111Z INFO safenode]
Running safenode v0.104.34-alpha.0
[2024-02-21T16:56:38.875122Z DEBUG safenode] Built with git version: 790d17d / alpha-test / 790d17d
[2024-02-21T16:56:38.875128Z INFO safenode] Node started with initial_peers ["/ip4/127.0.0.1/udp/4724/quic-v1/p2p/12D3KooWDuuWQfVPQuoJ6kjva6hHV3Q9iqgD2oUyK3VfujCBsyNy"]
[2024-02-21T16:56:38.875712Z INFO safenode] Starting node ...
[2024-02-21T16:56:38.880038Z WARN sn_transfers::wallet::hot_wallet] No main key found when loading wallet from path, generating a new one with pubkey: b7662c94e7a3533e3da3215bb72826e256c4edd60e2e11e30ecec7ee028b16ea1617a162028e12d8524574459e41bb06
[2024-02-21T16:56:38.883733Z INFO sn_networking::driver] Process (PID: 152056) with PeerId: 12D3KooWAswyPWHDxAgLqhTfWn175kEuXWRvhk4yXRRY1V8KvQZA
[2024-02-21T16:56:38.889350Z INFO sn_networking::driver] Self PeerID 12D3KooWAswyPWHDxAgLqhTfWn175kEuXWRvhk4yXRRY1V8KvQZA is represented as kbucket_key f111109c6fc413597fb12173e36eb48d8bff6f03766d6df9ada26e5647fc6d7c
[2024-02-21T16:56:38.897960Z INFO sn_networking::record_store] Attempting to repopulate records from existing store...
[2024-02-21T16:56:39.237082Z INFO sn_networking::network_discovery] Time to generate NetworkDiscoveryCandidates: 287.830284ms
[2024-02-21T16:56:39.248367Z DEBUG sn_logging::metrics] {"physical_cpu_threads":4,"system_cpu_usage_percent":100.0,"process":{"cpu_usage_percent":63.013695,"memory_used_mb":16,"bytes_read":249856,"bytes_written":0,"total_mb_read":11,"total_mb_written":0}}
[2024-02-21T16:56:39.237130Z INFO sn_networking::network_discovery] The generated network discovery candidates currently cover these ilog2 buckets: [(243, 1), (244, 2), (245, 5), (246, 5), (247, 5), (248, 5), (249, 5), (250, 5), (251, 5), (252, 5), (253, 5), (254, 5), (255, 5)]
[2024-02-21T16:56:39.694709Z INFO sn_peers_acquisition] Using peers supplied with the --peer argument(s) or SAFE_PEERS
[2024-02-21T16:56:39.694781Z INFO safenode]
[2024-02-21T16:56:39.694790Z DEBUG safenode] Built with git version: 790d17d / alpha-test / 790d17d
[2024-02-21T16:56:39.694796Z INFO safenode] Node started with initial_peers ["/ip4/127.0.0.1/udp/4724/quic-v1/p2p/12D3KooWDuuWQfVPQuoJ6kjva6hHV3Q9iqgD2oUyK3VfujCBsyNy"]
[2024-02-21T16:56:39.694891Z INFO safenode] Starting node ...
[2024-02-21T16:56:39.697279Z INFO sn_transfers::wallet] Attempting to read wallet file
[2024-02-21T16:56:39.697400Z DEBUG sn_transfers::wallet::watch_only] Loaded wallet from "/var/safenode-manager/services/safenode2/wallet" with balance NanoTokens(0)
[2024-02-21T16:56:39.697605Z INFO sn_networking::driver] Process (PID: 152068) with PeerId: 12D3KooWAswyPWHDxAgLqhTfWn175kEuXWRvhk4yXRRY1V8KvQZA
[2024-02-21T16:56:39.697680Z INFO sn_networking::driver] Self PeerID 12D3KooWAswyPWHDxAgLqhTfWn175kEuXWRvhk4yXRRY1V8KvQZA is represented as kbucket_key f111109c6fc413597fb12173e36eb48d8bff6f03766d6df9ada26e5647fc6d7c
[2024-02-21T16:56:39.697864Z INFO sn_networking::record_store] Attempting to repopulate records from existing store...
[2024-02-21T16:56:40.069626Z INFO sn_networking::network_discovery] Time to generate NetworkDiscoveryCandidates: 367.871279ms
[2024-02-21T16:56:40.069681Z INFO sn_networking::network_discovery] The generated network discovery candidates currently cover these ilog2 buckets: [(242, 2), (244, 5), (245, 5), (246, 5), (247, 5), (248, 5), (249, 5), (250, 5), (251, 5), (252, 5), (253, 5), (254, 5), (255, 5)]
[2024-02-21T16:56:40.074161Z DEBUG sn_logging::metrics] {"physical_cpu_threads":4,"system_cpu_usage_percent":100.0,"process":{"cpu_usage_percent":24.161074,"memory_used_mb":16,"bytes_read":0,"bytes_written":0,"total_mb_read":0,"total_mb_written":0}}
[2024-02-21T16:56:40.435628Z INFO sn_peers_acquisition] Using peers supplied with the --peer argument(s) or SAFE_PEERS
[2024-02-21T16:56:40.435695Z INFO safenode]
[2024-02-21T16:56:40.435703Z DEBUG safenode] Built with git version: 790d17d / alpha-test / 790d17d
[2024-02-21T16:56:40.435709Z INFO safenode] Node started with initial_peers ["/ip4/127.0.0.1/udp/4724/quic-v1/p2p/12D3KooWDuuWQfVPQuoJ6kjva6hHV3Q9iqgD2oUyK3VfujCBsyNy"]
[2024-02-21T16:56:40.435807Z INFO safenode] Starting node ...
[2024-02-21T16:56:40.441728Z INFO sn_transfers::wallet] Attempting to read wallet file
[2024-02-21T16:56:40.441846Z DEBUG sn_transfers::wallet::watch_only] Loaded wallet from "/var/safenode-manager/services/safenode2/wallet" with balance NanoTokens(0)
[2024-02-21T16:56:40.445477Z INFO sn_networking::driver] Process (PID: 152080) with PeerId: 12D3KooWAswyPWHDxAgLqhTfWn175kEuXWRvhk4yXRRY1V8KvQZA
[2024-02-21T16:56:40.445587Z INFO sn_networking::driver] Self PeerID 12D3KooWAswyPWHDxAgLqhTfWn175kEuXWRvhk4yXRRY1V8KvQZA is represented as kbucket_key f111109c6fc413597fb12173e36eb48d8bff6f03766d6df9ada26e5647fc6d7c
[2024-02-21T16:56:40.458461Z INFO sn_networking::record_store] Attempting to repopulate records from existing store...
[2024-02-21T16:56:40.854067Z INFO sn_networking::network_discovery] Time to generate NetworkDiscoveryCandidates: 391.202514ms
[2024-02-21T16:56:40.854117Z INFO sn_networking::network_discovery] The generated network discovery candidates currently cover these ilog2 buckets: [(242, 1), (243, 2), (244, 1), (245, 5), (246, 5), (247, 5), (248, 5), (249, 5), (250, 5), (251, 5), (252, 5), (253, 5), (254, 5), (255, 5)]
[2024-02-21T16:56:40.858151Z DEBUG sn_logging::metrics] {"physical_cpu_threads":4,"system_cpu_usage_percent":100.0,"process":{"cpu_usage_percent":21.686749,"memory_used_mb":17,"bytes_read":0,"bytes_written":0,"total_mb_read":0,"total_mb_written":0}}
[2024-02-21T16:56:41.197631Z INFO sn_peers_acquisition] Using peers supplied with the --peer argument(s) or SAFE_PEERS
[2024-02-21T16:56:41.197703Z INFO safenode]
