OFFLINE Will it be a Quicky? (run 4)
Don’t we already have an install script? :slight_smile:
Btw, if you wanted to write a Powershell script, we need one for a native Windows installation.
You mean https://install-safe.s3.eu-west-2.amazonaws.com/install.sh ?
This is a wee wrapper that got out of hand… I’ll put it up on github later but something like this so far
#!/bin/bash
# script to set up comnet - community testing for the SAFE network
#TO DO
# get the latest versions
# make paths configurable
# add warnings
# if we set the same port for everyone, what happens?
# write a Powershell script to set up a Linux VM for Windows users
echo "================================================================================================"
echo "This script is only for 'vanilla' linux systems on standard x86-64 PC hardware"
echo
echo
PUBLIC_IP=$(echo `curl -s ifconfig.me`)
NODE_PORT= #TO DO if we set the same port for everyone, what happens?
TMP_DIR=/tmp/comnet
SAFE_ROOT=/home/USER/.safe
NODE_BIN_PATH=$SAFE_ROOT/node
SAFE_BIN_PATH=$SAFE_ROOT/sn_cli
LOG_DIR_PATH=$SAFE_ROOT/logs
COMNET_CONN_INFO=https://sn-comnet.s3.eu-west-2.amazonaws.com/node_connection_info.config
SN_NODE_ASSET=https://github.com/maidsafe/safe_network/releases/download/safe_network-v0.51.7/sn_node-0.51.7-x86_64-unknown-linux-musl.tar.gz
#DATA_DIR_PATH=$SAFE_ROOT/data_dir
SN_CLI_QUERY_TIMEOUT=180
RUST_LOG=safe_network=info,qp2p=info
echo "This script will install comnet - community testing for the SAFE network"
echo "comnet files will be installed in "$SAFE_ROOT
echo "log files will be stored in "$LOG_DIR_PATH
#echo "data files will be stored in "$DATA_DIR_PATH
echo
echo
echo "Your public IP address is " $PUBLIC_IP
echo
# clean up from last testnet
rm -rf $SAFE_ROOT
if [ -d "$TMP_DIR" ]; then rm -Rf $TMP_DIR; fi
# grab latest sn_node and prepare it for use
mkdir $TMP_DIR && cd $TMP_DIR
wget -q $SN_NODE_ASSET
#TO DO add code to extract the current version nos
tar xvzf sn_node-0.51.7-x86_64-unknown-linux-musl.tar.gz
mv sn_node sn_node-0.51.7
chmod +x sn_node-0.51.7
chown $USER:$USER sn_node-0.51.7
# get sn_cli
cd
curl -so- https://install-safe.s3.eu-west-2.amazonaws.com/install.sh | bash
mkdir -p $NODE_BIN_PATH
cp /tmp/comnet/sn_node-0.51.7 $NODE_BIN_PATH/
cd $NODE_BIN_PATH
# Use a symlink so it is easy to keep various versions of sn_node around to easily switch if req'd
#Or maybe not? - skip the symlinks to KISS
ln -s sn_node-0.51.7 sn_node
# set up the network
safe networks add comnet $COMNET_CONN_INFO
safe networks switch comnet
safe networks
safe networks check
# Add a node
$NODE_BIN_PATH/sn_node \
--skip-auto-port-forwarding \
--log-dir $LOG_DIR_PATH \
--public-addr $PUBLIC_IP:$NODE_PORT
What happens if several nodes attempt to connect to one section at the same time all with the same port no?
I need to study the existing install.sh a bit closer perhaps.
Ok…
If you were going to write a Powershell script, you could write one to do a native Windows installation, rather than setting up a VM. We need to support native Windows installations, that’s a big missing piece just now. You could PR that to the main repo.
Also btw, the node install command is fixed in the recent release, so there’s no need to set that up ‘manually’ any more.
If you wanted to have different versions of the node, there’s also an argument on the install command for specifying the path.
I don’t want to write a Powershell script but I know one will be needed.
On the todo list for later today is to install Kali on my old Thinkpad so I’ll maybe dual-boot that if I can find a Win10 install .iso
Ok cool. All I’m saying is, it would be useful if the script installed sn_node directly on Windows, rather than setting up a VM, since that’s something we need for the main repo and it’s a scenario we should support. It’s a poor experience for Windows users if they need to setup WSL and whatnot.
so simply safe node install will automagically do whats req;d?
Yeah, and there’s --node-path and --version arguments for that, if you wanted to have multiple nodes sit alongside each other, for whatever reason.
Indeed, thats why I need a Windows box lying around rather than reluctantly firing up a VM if I have no other choice than to sully my soul interacting with M$ windows
On second thoughts perhaps we should forget about that just to KISS?
This is to be a script for a relative n00b to quickly and relatively painlessly get as far as PUT/GET cat and dog on the community nets
Of course, having declared all those vars at the top, if you chose not to accept the defaults it could be quite flexible. But anyone who needs that flexibility probably doesnt need this script… Hmmm
I absolutely agree with this. Many things are out there in principle - fancy installers for multiple platforms, auto-completion, graphic design for telephones, documentation, and what have you. It’s just that in practice they don’t work, or are out of date.
The reality is forum members can’t even put/cat a little .gif and/or have a network stay up for more than a couple of hours. We need something practical and working, no matter how small. “Hello world!”, ping network.
I was pondering this same thing recently: create a few VMs in QubesOS for a local network and use a VPN to give each a different IP. Presumably it would just be a matter of putting those IPs into the config file @chriso? (In case you’re not familiar with it, QubesOS allows you to run independent VMs on the same desktop OS).
Yeah, quite possibly. I’ve no idea how the network deals with that kind of virtualised networking though. Does it work ok when you run nodes from more straight forward VMs?
I’ve not tried it for a while TBH. It used to be OK - mostly - back in the day
