Clear, thank you ![]()
I do not need to run PowerShell in administrator mode, it also works without it.
On the other hand, it was only when I started PowerShell ISE in administrator mode that the message appeared:
safeup.exe - system error - due to missing VCRUNTIME140.dll
the message did not appear before.
Ah I see. That’s a useful piece of information - thanks!
Can I ask, which version of Windows are you running?
Glad I could be of help
I use Windows 10 Pro
We had an install script before where installing the VC++ runtime was part of it. Might need to re-consider that again.
It would be good if someone else tried installing Testnet on Windows to see if they had a similar problem with a missing file.
But you should probably to change this command in the manual - the term ‘export’ is not recognized as the name of a cmdlet, function, script file, or operable program
Yeah, the instructions for this particular testnet were inadequate.
To be honest, there is no real need to keep changing these. We should just have some boilerplate text we can copy and paste. Will make sure that’s sorted for subsequent testnets.
What you were missing on your machine was the VC++ runtime. I already had that installed on my machine, which is why it worked straight away for me. However, this is a dependency we’re already aware of.
How can I find the multiaddresses of my own nodes?
(for example "/ip4/165.22.123.138/tcp/41377/p2p/12D3KooWBPdhoD9uSbtwFeiQWmTZT2Lhaz2HRrgtLWauMwYQK1pK"
Edit: found it
sn_networking::event] Local node is listening on "/ip4/176.58.124.107/tcp/37421/p2p/12D3KooWEFRkqnaJ3Dzpnq3qWu1DbQc3uqHC9GehqpBKdLYg9oZr"
I was about to reply but you got it! Just grep for ‘listening’ in the first log file created.
The awkward thing is that this message seems to only appear once and when the node starts up. So when the log file is eventually deleted after about a week you can never tell what your node id is! You can find your port number and you should know your IP addresses but not the node id.
Feature request: have the ‘listening’ string repeated in the logs every few mins.
Perhaps saved in a file same as pid is?
I found it useful using the safenode_rpc_client if you start up your node with --rpc 127.0.0.1:1234:
Then safenode_rpc_client 127.0.0.1:1234 netinfo shows:
Node's listeners:
Listener: /ip4/127.0.0.1/tcp/12000
Listener: /ip4/192.168.X.Y/tcp/12000
In addition doing safenode_rpc_client 127.0.0.1:1234 info shows:
Node info:
RPC endpoint: https://127.0.0.1:1234
Peer Id: <YourPeerId>
Logs dir: <YourLogPathDir>
PID: #
Binary version: 0.86.5
Time since last restart: 253094s
I too am seeing up to 100s of connected peers per node (instant report) when scanning for connected peers on a per minute basis via the RPC method noted here. Below is an updated graph from the original comments noted here :
Updates:
- Added panel for # Unique Peers Connected per Min
We’ve been digging deeper here this week and it seems:
- there’s 2 conns for every peer. And kad should maintain conns for all peers in the routing table. This would mean ~150 open conns on each node would make sense
- multiplexing should mean we use the same port for all IN conns and all OUT.
- Right now we open alot of ports, which seems to be because of a libp2p default dial condition meaning the kad layer is opening hundreds of connections on new ports.
- this is memory intense.
There’s fixes for that and other conn related things in the pipeline ![]()
An update on the testnet in general:
Mem issues are obviously still about in this branch, and we’re down to 11 nodes/droplet now.
With that, we’ve only got two “full” nodes so far (and those could still be pruning data).
mem on the surviving nodes is ~350mb atm.
I can still get our test data fine ![]()
Your pipeline or libp2p’s?
Both really. Libp2p needs to get QUIC as first class hole punch citizen and we need to work with what they have and we can contribute to. So nothing to worry us, but progress needs to happen.
While that happens we can move forward to finalise upgrades, payments etc. So all good
Aye, @bzee has worked up some PRs for libp2p which are waiting in the wings there.
We have that tested but can’t merge until a release there.
And then we’ve other related work in the safe codebase on the go too.
Lost 89% of the original nodes and the test data is still there.
Damn fine work gentlemen ![]()
When this is truly multiplexed (QUIC) then I feel hundreds of nodes per PC is gonna be simple. Great to see kad doing what kad should do here and doing it well. @joshuef does a bunch of churn tests with 6 times 100% node loss and it’s very good, really good.
