node_earnings_tracker
Autonomi network node earnings tracker
[cite_start]This application monitors incoming ERC20 transfers (e.g., Autonomi tokens) on the Arbitrum network using the Alchemy API[cite: 1, 18].
Setup & Configuration
- [cite_start]Get an API Key: You need to obtain a free API key from Alchemy[cite: 1, 19].
- Initial Launch: When starting the app for the first time, you will be prompted to provide:
- [cite_start]Alchemy API Key[cite: 1].
- [cite_start]Wallet Address: The address you wish to monitor[cite: 1].
- [cite_start]Token Contract Address: The address of the token you want to track[cite: 1].
- [cite_start]Example (Autonomi):
0xa78d8321B20c4Ef90eCd72f2588AA985A4BDb684[cite: 1].
How to Run the App
The app is provided as a standalone executable. You do not need to install Python or any libraries to run the files from the Releases section.
Windows
- Download
NodeEarningsTracker.exe. - Double-click the file to launch.
- If Windows Defender shows a warning (“Unknown Publisher”), click “More info” and then “Run anyway”.
Linux
- Download
NodeEarningsTracker-Linux. - Open a terminal and make the file executable:
chmod +x NodeEarningsTracker-Linux
Run the app:
./NodeEarningsTracker-Linux
macOS
- Download and extract
NodeEarningsTracker-Mac. - Note: Since the app is not signed by Apple, you cannot simply double-click it. Right-click (or Ctrl+Click) the app and select Open.
- In the dialog that appears, click Open again.
Data Storage
[cite_start]The app stores your settings and transaction history locally on your computer using platform-aware folders[cite: 13]:
- [cite_start]Windows:
C:\Users\<username>\AppData\Roaming\ArbEarningsApp\[cite: 13] - [cite_start]Linux:
/home/<username>/.local/share/ArbEarningsApp/[cite: 13] - [cite_start]macOS:
/Users/<username>/Library/Application Support/ArbEarningsApp/[cite: 13]
Files created:
- [cite_start]
config.json: Stores your default wallet and token contract[cite: 16, 17]. - [cite_start]
transfers.csv: A ledger of all incoming ERC20 transfers[cite: 16, 18].
For Developers (Running from Source)
If you wish to run the .py file directly, the following modules are required:
| Module | Install Command | Purpose |
tkinter |
Included with Python | [cite_start]GUI [cite: 4, 5] |
requests |
pip install requests |
[cite_start]API calls to Alchemy [cite: 6, 7] |
matplotlib |
pip install matplotlib |
[cite_start]Charts [cite: 2, 8] |
appdirs |
pip install appdirs |
[cite_start]Cross-platform data folder management [cite: 9] |
pyinstaller |
pip install pyinstaller |
[cite_start]For creating standalone executables [cite: 12] |
