Trying to make sense of the origional reason margin trading is being removed.
It was a flash crash that did this. Soooo putting in a massive buy wall to keep the market up
is probably poloniex.
What were the other coins being removed from margin? We should also check if there are large buy walls on those coins. That would be a smoking gun. I can only remember FCT.
It looks like a buy wall may have evaporated. Post 16th August, FCT and MAID seem to have
a very solid bottom.
FCT is boincing of a solid 0.0003 and MAID of 0.000015
Anyone else able to take a look at the rest?
If there is a smoking gun, i’m likely to put a lot more gunpowder in and buy up as many cheap coins as I can.
I agree FCT is has the same fate as maid. CLAM was the pair involved in the crash but that was the opposite, too large long position and too thin buy wall created an instant crash.
BTS is the only other market being removed from margin but other exchange are more liquid in trading that coin so I think that is less of an issue.
MAID is primarily traded on poloniex and always was, and FCT only has a few other markets. The pair with the largest upside potential is definitely MAID.
So also a short squeeze on FCT? It does look like the FCT price is rising.
Also keep an eye on FCT price action? Where ever the FCT price action is going, so will MAID?
Short term I say that analysis would hold accurate.
Do you think that FCT chart shows they tried to dump the price down at the same time as MAID and it got bought up and started running away from them?
I do suspect.
The orange circles in the above chart show a suspicious solid bottom on both FCT and MAID starting
after the 16th of August. Too much of a coincidence.
Considering all of the above, it does look like FCT has started a runaway price movement.
Maybe they jettisoned some chap maids here.
FCT and MAID certainly started to climb at the same time.
They are both being removed from margin trading… the coincidences keep lining up.
They can’t afford a sell wall, maybe they can inject a few cheap coins every now and again.
Be my guest… i’ll buy all their cheap coins.
FCT is far more expensive that MAID, which is probably why they chose to knock down maid for a while.
Could be a buy signal for FCT, eh? I’m sticking with MAID though. Looks like MAID is recovering
quite well after their price hammer.
Man, this is all speculation… but it seems to add up.
This is where MAID is.
I see BTC 0.00002 very shortly.
Assuming the buy wall is not only just a tool to prop up the market price, what if it is the actual amount
needed to cover poloniex shorts?
This would mean, poloniex needs near 3,000,000 MAID!!!
The current order book… i can’t download the whole thing, but if force to by at least 1,000,000
will knock the price up to 0.00003.
I see where you got your estimate for 10K satoshis.
Poloniex needs to cover these shorts. To recover 3Million maid, in the current order book,
we are going to BTC 0.0001.
Possibly the strongest MAID buy signal in the history of the project.
The moment you realise poloniex is going to have to make it feel like xmas for all of use while covering their shorts.
When I get time… or if someone else can, caption this for the MAID price, it will be legendary.
It is speculation that the wall is poloniex to cover the margin positions. I feel it’s reasonably certain, I mean anyone who has followed the price / order book for a reasonable amount of time knows it’s not normal.
We know by poloniex own admission all margin positions must be closed. Add the Wall + their forced exit and no more shorting allowed. This means anyone with an open short right now has their pants down. Because anyone buying, means that the shorters in the end will be paying for our cheap coins.
Buy now and make the shorters pay the premium, the sale won’t last forever this is a very unique opportunity. Long term with Fleming on the horizon, I see this as a perfect storm. I’m all in.
Paying any price for our current cheap coins… i’m not handing them over until launch, or at least for a ridiculous return. I think we are about to experience pricing in of value.
How would Polo decide which price to place the wall at if it is them? The wall used to be at a higher price, didn’t it? There were also some periods where a wall got ate up and then didn’t exist at all if I recall correctly. For the Polo theory to hold, wouldn’t they want to always have a bottom in place?
Perhaps they were probing the market for a stable place to keep a bottom?
At the higher price I think they were burning through too many bitcoins.
They could have been trying to find the sweet spot?
It is all a massive speculation.
Looks like the support at 1500 was removed to see how the market would react…
Didn’t help so it was put back.
I guess they are lucky that MAID has never been lower. So they started buying at the previous bottom and had lots of people who would sell to them. In order to get the best price for their clients (the evil shorters, haha) they moved the wall lower. However, volume since then has slowly dried up and the price is slowly creeping up. Once an uptrend sets in, bots will end up front running poloniex and the market finds its fair value.
Anyone reading this on the other side? With shorts in place? Or would they ask you not to talk about the experience
MAIDUSD shorts are still looking good, considering high resistance for BTC and a likely drop back to 8500 USD soon.
Squeezy Squeezy…
Wake me up when maid is at 5$ and not in the cents range anymore :money_mouth_face:
Edit: But I think this will take some years from now :cry:
$2.50 once this short squeeze is over.
The price action will turn heads just as Fleming is released.
$3 - $5 per token pre launch won’t be difficult to acheave.
:joy: What are the shorts going to do, give us more cheap coins!! It’s like pouring petrol on a fire at this point.
We will see. How long are we talking about the price already? I am in since 2015 and we are still talking about cent prices :pensive:
Love your optimism Zoki. That’s a 15x increase coming up at Fleming. Has anything gone 15x since the crypto winter?
