MAID(Omni) to ANT conversion
Hello, I’ve been holding MAIDs Omni token since 2013. Was researching the current state of the token and found this: Process Overview | Autonomi
Can I still use that process or is it too late? And if relevant, are there any plans to continue MAID Omni support?
Thanks for reading.
Yes that’s the correct process the Autonomi tokens are changed 1:1 for your burned Omni maid.
There is ongoing support for Omni maid burns up untill 2028 if I remember correctly.
But check the schedule as time goes on the tokens will be sent out less frequently currently it’s every 2 weeks and then I think it drops to quarterly.
