Add works OK, Start Kill and Remove not so much Quit works fine.
Got some messages over writing the table but that cleans up by running the arrow up and down.
I installed this alacritty that I am not used to, I need to remove that entirely and see how it goes with the std Ubuntu terminal
UPDATE:
Add and Remove work fine, this cant connect to a network at the moment so obv Start and Kill cant be expected to work. Looking good so far
Can you elaborate? It’s a new Ub24 install but I copied user settings over from my previous Ub22 system.
EDIT: @joshuef my system won’t boot this morning. Anything the TUI messes with that I should look at? I should never have given it sudo EDIT: see end
@chriso might the TUI have messed with /var/safenode-manager and if so is it safe/worthwhile to try removing it? I’m looking at what system files have been changed in the past 24 hours, but those were probably changed by running snm itself. Any other clues? EDIT: see…
EDIT: no worries, I think best to reinstall so I can get on.
Hey @Southside, what does the start do? Nothing? It is actually plugged in and it should work, though I’ve seen some cases earlier where it was not working, but it should’ve been fixed.
The TUI uses the node-manager APIs under the hood and it should just access /var/log/safenode + /var/safenode-manager and either one of these dirs
the tui is just a wrapper around the safenode manager, so it’s not doing anything that’s not honestly.
I mean in the code, there’s some detection of terminal things that may not be working well. Would be good to know if it works with another terminal for you.
Sorry, but I won’t be touching it again for a while. Maybe it wasn’t what borked my system but I reboot every day and that’s the only unusual thing I did yesterday, and it did mess itself up.
willie@gagarin:~$ sudo systemctl status safenode7
× safenode7.service - safenode7
Loaded: loaded (/etc/systemd/system/safenode7.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2024-05-08 14:46:27 BST; 52s ago
Process: 74421 ExecStart=/var/safenode-manager/services/safenode7/safenode --rpc 127.0.0.1:39841 --root-dir /var/safenode-manager/>
Main PID: 74421 (code=exited, status=2)
CPU: 3ms
May 08 14:46:27 gagarin systemd[1]: safenode7.service: Scheduled restart job, restart counter is at 5.
May 08 14:46:27 gagarin systemd[1]: Stopped safenode7.
May 08 14:46:27 gagarin systemd[1]: safenode7.service: Start request repeated too quickly.
May 08 14:46:27 gagarin systemd[1]: safenode7.service: Failed with result 'exit-code'.
May 08 14:46:27 gagarin systemd[1]: Failed to start safenode7.
I get this on all my nodes now - cant get any started on this box that i tried out launchpad on. I started 20 nodes on another box here - using safenode-manager and they are working correctly if somewhat feebly AFAICS
EDIT: I have no ~/.config/node-launchpad on my main machine.
Thats yet another SAFE/Autonomi directory to keep an eye on - along with ~/.local/bin , /var/safenode-manager, /var/log/safenode, ~/.local/share/safe/client - did I miss any? Lots of places to check for something no right…
I know proper documentation will come along soon but it would have been nice to know about the supposed prescence of ~/.config/node-launchpad when Im trying to make this work.
:CLARIFICATION
The node 7 shown above is a set of 10 I tried to start manually last night after I remembered
so I didnt expect to actually run nodes with this - didnt stop me trying to start nodes that had already been added by launchpad…
Fair enough. It could be the way the service files are being managed there is causing some issues perhaps. We’ll hopefully get to the bottom of it soon enough, and we’ll have sudo requirement removed via this pr, which should make that feel a bit safer at least (and make debugging what could be happening her ea bit easier).
If you can cut us a bit of a break here, there is a necessity to have different directories when it comes to the distinction between system-wide vs. user-mode. Soon, we’ll offer the option to run services in user-mode, but the option for running system-wide will still be there. This is because system-wide still makes sense in some cases. Services in user-mode require an active user session, which is not appropriate for all use cases. Plus, there are some service managers, like OpenRC, that don’t support user-mode services.
I’ll need to speak to Roland about ~/.config/node-launchpad. As the name implies, ~/.config is for configuration, not data, so nothing related to the node manager data should be going there. If anything, this would be for things like custom key-bindings related to the TUI itself.
