Edit: 1. This might not be needed after next update. 2. Since restarting your nodes is not recommended for the network health, avoid running this without reason. But nevertheless, prefer this instead re-creating your nodes.
Looks like you can keep your nodes productive by just restarting them. Afaik, reset is not needed. This is based on my few days tests, so could someone confirm it. I suggest to run this if your nodes rewards start to degrade.
Maybe a few people who knows scripts could check and review it? I would be suspicious for any script published on any forum…
But here is the script:
#!/bin/bash
# Run antctl status, collect service names
tmpfile=$(mktemp)
echo "Collecting service names with antctl status.."
antctl status > "$tmpfile"
# Find the names
services=$(awk 'NR>5 {print $1}' "$tmpfile")
# Remove temp file
rm "$tmpfile"
# Count services
service_count=$(echo "$services" | wc -l)
# Run stop - start for every service
for service in $services; do
echo "Restarting service: $service"
# Stop service
COMMAND1="antctl stop --service-name $service"
echo "$COMMAND1"
eval "$COMMAND1"
# Restart with interval
COMMAND2="antctl start --service-name $service"
echo "$COMMAND2"
eval "$COMMAND2"
echo "Sleeping 60 seconds."
sleep 60
done
# Print service count
echo "Number of nodes restarted : $service_count"
Be aware, as this is harmful to the network in time this behaviour may very well mean nodes actually have to initiate permanent bans on nodes doing this. It also could lead to reduced payments as you miss chunk store requests while restarting your node.
It’s the balance we try to make with small inconsistent nodes and then people purposefully causing churn on the network that is an issue.
But the problem is that currently people are resetting the nodes to keep them healthy, which is AFAIK much worse to the network. Just restart is a lot softer way, and downtime is less than a minute / node.
It should not happen. I suspect if folk run as many nodes as possible on a machine then things like that will happen, but otherwise it should not happen.
We need to somehow alert folks that they are just running too many nodes. The launchpad I believe tries to measure how many nodes to run on disk space at least, but we likely need to do more. It’s very hard to make it simple to run nodes but also avoid abuse at the same time. Not that folk always will purposefully do that for abusive reasons but I think some people are running as many nodes as they can and then doing things like restart them all periodically.
It’s not good for them and hopefully the network does manage to find those nodes and shun them, but it all takes time. so we likely need to do more, but I think people will push as far as they can and then do scripts like this so squeeze some more out of node count and so on. It’s not good for the network and that means it has to be less good for the operators acting like this really.
It’s just not clear to people that purposefully switching nodes on and off again repeatedly is a bad thing, when you think about it, then it obviously is, but it won’t stop folk dong it.
VPS’s get a lot more ant than home ones, and the nodes from home gradually reach 0 yield. So my hypothesis is that over time they lose connectivity, while those in the cloud don’t because of the better internet. I had to reset all my nodes to get mining going again… this happened on all 4 of my fiber lines.
This is the reason i wrote that. Even moderate amount of nodes seems to degrade over time. I’m running ~100 nodes with 8G / 2T, 4core i5, 1G symmetrical fiber.
I used to reset and create new nodes maybe once a week, but if just stop and start is enought, it is much nicer.
Best would be if I could just start the nodes and let them run forever untouched.
Yes, switching off and on is not good, but resetting, ie removing all and creating new ones is much worse.
Just stop and start should not cause all stored data to be duplicated. But remove and create new will cause that.
It may very well be related to an issue we are working on with relay nodes. Some nodes are relaying through other nodes and they may not have good direct connectivity. So those nodes that require to relay through others may be suffering. It’s being worked on for sure.
Well, that’s exactly how I acted in December and January. And the nodes worked with 3-4 times more traffic than now and I use bridge mode and I don’t have routers to limit me. After 11.02 it worked fine for 5 days and then it started decreasing yield until it got to 0 on all my machines. After a reset it was fine and now I’m waiting to see if they degrade again.
I haven’t checked because I was using antctl, and it’s broken above 500 nodes. But @neo analyzed my logs from one machine and said they were connected to 1.3 million other nodes. Now I’m using dockers with 200 nodes each and I’ll be able to see better what’s going on, of course if antctl allows me…
I wonder if it is HW specific or people are pushing their machines too much. My machines with most nodes have 500 nodes each and they do antctl status fine in about 10 minutes.
Actually when you mentioned this, same for me. I was only running 4 nodes back then, but they earned steadily. I have NAT and used upnp back then (now port forward).
Example it might not look busy running 6000 nodes but you may use too much swap and the cpu needs to be fed from RAM or it will be like running into a brick wall.
I’ve have a similar feeling as @dirvine Too many nodes causes problems in connections over time, probably because some limitations in hardware.
I ran 1500 nodes since the start and they just keep earning except for a power outage on Monday.
I seen people on discord running 5000 and only getting 1-2 Ants while my 1500 x 2 nodes earned 50-60 the last Sunday.
For example DDR4 RAM is about 10 times faster than SSD random read speeds, with speeds up to 25GB/s.
