Ethereum Portal Network (data partner idea)
The Portal Network is a peer-to-peer protocol that runs parallel to Ethereum. Ethereum data is distributed across the Portal Network, instead of being copied in every individual node. This allows users to access Ethereum data with minimal hardware and bandwidth requirements and almost instant syncing.
Rather than reinventing the wheel, a full Ethereum node could dump its data into Autonomi and instantly satisfy the goals of the Ethereum Portal Network.
