Community Test 13 November - offline
Get a carry out from Kokome in Shawlands - superb noodles and tempura
That was my issue. What made you think of going to 21.04?
trial and error, 18.4 was not working at all, I think that has GLIBC 2.27 and it wanted 2.29 so I tried 20.04 that started up but rough and on 21.04 it is cruising.
:laughing:
see if you can get this safe files get “safe://hyryyryynmthio981wjhwiq5k3nueg3jm58wiu7e8nbsesas3xmc1j517yzyoeuy?v=hhuy1rk1mi9kbtmi6ux6sbhrs6asj4gae8anx6w8rstj4mk5qhrey”
Its simply the default contents of /var/www on a fresh 20.04 install on AWS
However from that instance the get is hanging
ubuntu@ip-172-31-1-108:~$ safe files put -r /var/www/
FilesContainer created at: "safe://hyryyryynmthio981wjhwiq5k3nueg3jm58wiu7e8nbsesas3xmc1j517yzyoeuy?v=hhuy1rk1mi9kbtmi6ux6sbhrs6asj4gae8anx6w8rstj4mk5qhrey"
+  /var/www/html
+  /var/www/html/index.html  safe://hy8oyryybgk87oans8dp763dthygrtwdbkud1we8nph5mox6z3izatppyn5ay
ubuntu@ip-172-31-1-108:~$ mkdir safe_gets
ubuntu@ip-172-31-1-108:~$ cd safe_gets/
ubuntu@ip-172-31-1-108:~/safe_gets$ safe files get "safe://hyryyryynmthio981wjhwiq5k3nueg3jm58wiu7e8nbsesas3xmc1j517yzyoeuy?v=hhuy1rk1mi9kbtmi6ux6sbhrs6asj4gae8anx6w8rstj4mk5qhrey"
File [2 of 2]: html/index.html
⠉ [00:00:00] [----------------------------------------] 0B/10.66KB (0B/s, 0s)  Transfer
EDIT: Meantime I will try upgrading glibc - I need an otherwise vanilla 20.04 for the other work
That doesn’t seem right to me - on both the laptop and the AWS instance I have 2.31
willie@leonov:~$ ldd --version
ldd (Ubuntu GLIBC 2.31-0ubuntu9.2) 2.31
Copyright (C) 2020 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Written by Roland McGrath and Ulrich Drepper.
Yeah IDK it is doing my head in, probably lack of understanding.
I installed Ubuntu 18.04 on my laptop and just checked GLIBC is 2.27.
Maidsafe binaries run just fine on 18.04, I thought mine may be causing me grief because I built them on 21.4 but building on 18.04 made no difference.
@aatonnomicc Do me a favour and tell me what you get from
ldd --version please?
Yeah, I seriously think we are barking up the wrong tree here. Sorry
administrator@Test-Node:~$ ldd --version
Ta much. So we know glibc 2.31 works OK - It is something else thats wrong.
in case ay one wants some random mp3’s for test purposes
just finished uploading
+  ./01-Introduction.mp3      safe://hygyy1yyba6sybd99zexadnddqx9k6faz65uxwgjz3rxdmuos8muzyussftdy
+  ./02-Breath.mp3            safe://hygyy1yybzek3ft4i4jccjag4rmbfzrw6bs1xps5hk73srm75s6dfo5jijxuo
+  ./03-Meditation.mp3        safe://hygyy1yybruskumxksb6hmrj3p5yy9pb9fh373is7rq8jzj9b81n1hr17m4do
+  ./BegBlagandSteal.mp3      safe://hygyy1yybp9edeorgb1wyu9yyoofd9nuz3czc9339kx7gdcumq9fx8r6sj9ey
+  ./ROLLNSQUARE.mp3          safe://hygyy1yybb4w1ck8hwaensjcz7yfngmjg7gs7yaykyyz7nabsaadfahs9tf4y
+  ./md5-01-Introduction.txt  safe://hy8oycyybs6cduin3xrp5t1diugx47749qjbfiqgfnokiwnmxda5x5j7w3szo
+  ./md5-02-Breath.txt        safe://hy8oycyybt3xkopcw8pikxzssytz1mr1tgznmhnrhm4sotphwk19ryqfa847o
+  ./md5-03-Meditation.txt    safe://hy8oycyybe9ok3hgstey15i7j4nczhf43b66foon9ydy13aprzfob88rb9pfo
+  ./md5-BegBlagandSteal.txt  safe://hy8oycyybcigujx9q677d7hb8spqx9zkwre5hyi1rn3u4xkdoi5hicu1tuguy
+  ./md5-ROLLNSQUARE.txt      safe://hy8oycyybthriwi5n6ecmtisi4t5bpwkgu56deey5scwnbf3a3agg7fr7bu3y
+  ./test.sh                  safe://hyfeboyybbuwyz5amchxwz3x67u5twrozb1djhbgdgf3hw7gpjft37koa9wmy
Did you try feeding ROLLNSQUARE to the wife for her tea?
iv been landed with a crying baby so hopefully ill get a better offer than coco pops
First cat with test_image.jpg was successful and fast.
Next I tried put commands, and checking uploaded files with cat.
And they are taking too long.
Test #2 for test_image.jpg was slow, but successful.
Looks like network is semi-dead.
Will try disonnect test now.
Sad that I wasn’t able to test disconnect earlier.
Thank you @anon26713768 for this setup! Amazing! I was successfully able to join the network and start processing chunk writes. My node eventually ran out of disk space on an initial run.
Restarted the sn_node using a different --root-dir path that has > 1TB of free space while testing out the --max-capacity parameter option set to 1TB in bytes.
@shu Please give us your OS and version numbers please. Thanks
my node is out of space looks like this test net was a winner and a victim of its own success
 ERROR 2021-11-14T19:05:58.809612Z [sn/src/routing/routing_api/dispatcher.rs:L188]:
         ➤ Error encountered when handling command (cmd_id 2114919936.0): Database(NotEnoughSpace)
 ERROR 2021-11-14T19:05:58.886296Z [sn/src/routing/routing_api/dispatcher.rs:L188]:
         ➤ Error encountered when handling command (cmd_id 117847518.0): Database(NotEnoughSpace)
 ERROR 2021-11-14T19:05:59.299187Z [sn/src/routing/routing_api/dispatcher.rs:L188]:
         ➤ Error encountered when handling command (cmd_id 659265704.0): Database(NotEnoughSpace)
 ERROR 2021-11-14T19:05:59.592541Z [sn/src/routing/routing_api/dispatcher.rs:L188]:
         ➤ Error encountered when handling command (cmd_id 1522856357.0): Database(NotEnoughSpace)
Currently running a LXC alpine container (version 3.13) on x86-64 hardware.
THis is obviously working well for most folks. Frustrated I can’t join in more effectively but all in all I think a big hand to @anon26713768 for getting us this far.
Consider your beer account incremented, @anon26713768
