Community Test 13 November - offline
Unfortunately we are unable to establish a connection to your machine (89.243.55.83:63732) either through a public IP address, or via IGD on your router. Please ensure that IGD is enabled on your router - if it is and you are still unable to add your node to the testnet, then skip adding a node for this testnet iteration. You can still use the testnet as a client, uploading and downloading content, etc. https://forum.autonomi.community/
 WARN 2021-11-14T16:31:08.419160Z [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\qp2p-0.27.2\src\connection.rs:L492]:
         ➤ Stopped listener for incoming bi-streams from 134.122.104.91:12000 due to error: TransportError(Error { code: INTERNAL_ERROR, frame: None, reason: "endpoint driver future was dropped" })
 WARN 2021-11-14T16:31:08.419222Z [sn\src\routing\core\comm.rs:L445]:
         ➤ handle_incoming_messages {connection_id=2434083580464 src=134.122.104.91:12000}
         ➤ error on connection with 134.122.104.91:12000: ConnectionLost(TransportError(Error { code: INTERNAL_ERROR, frame: None, reason: "endpoint driver future was dropped" }))
 WARN 2021-11-14T16:31:08.419344Z [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\qp2p-0.27.2\src\connection.rs:L492]:
         ➤ Stopped listener for incoming bi-streams from 46.101.57.70:12000 due to error: TransportError(Error { code: INTERNAL_ERROR, frame: None, reason: "endpoint driver future was dropped" })
 WARN 2021-11-14T16:31:08.419371Z [sn\src\routing\core\comm.rs:L445]:
         ➤ bootstrap {bootstrap_nodes=[46.101.57.70:12000, 46.101.75.100:12000, 134.122.98.1:12000, 134.122.98.3:12000, 134.122.98.6:12000, 134.122.98.12:12000, 134.122.98.13:12000, 134.122.98.15:12000, 134.122.98.16:12000, 134.122.98.17:12000, 134.122.98.20:12000, 134.122.104.91:12000, 167.172.51.210:12000, 167.172.53.166:12000, 167.172.54.89:12000]}
         ➤ handle_incoming_connections
         ➤ handle_incoming_messages {connection_id=2434083594816 src=46.101.57.70:12000}
         ➤ error on connection with 46.101.57.70:12000: ConnectionLost(TransportError(Error { code: INTERNAL_ERROR, frame: None, reason: "endpoint driver future was dropped" }))
 WARN 2021-11-14T16:31:08.419448Z [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\qp2p-0.27.2\src\connection.rs:L492]:
 WARN 2021-11-14T16:31:08.419487Z [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\qp2p-0.27.2\src\connection.rs:L492]:
         ➤ Stopped listener for incoming bi-streams from 134.122.98.12:12000 due to error: TransportError(Error { code: INTERNAL_ERROR, frame: None, reason: "endpoint driver future was dropped" })
 WARN 2021-11-14T16:31:08.419556Z [sn\src\routing\core\comm.rs:L445]:
         ➤ handle_incoming_messages {connection_id=2434080163632 src=46.101.57.70:12000}
 WARN 2021-11-14T16:31:08.419580Z [sn\src\routing\core\comm.rs:L445]:
         ➤ handle_incoming_messages {connection_id=2434083566112 src=134.122.98.12:12000}
         ➤ error on connection with 134.122.98.12:12000: ConnectionLost(TransportError(Error { code: INTERNAL_ERROR, frame: None, reason: "endpoint driver future was dropped" }))
 WARN 2021-11-14T16:31:08.419736Z [sn\src\routing\core\comm.rs:L445]:
         ➤ handle_incoming_messages {connection_id=2434083255984 src=167.172.53.166:12000}
         ➤ error on connection with 167.172.53.166:12000: ConnectionLost(TransportError(Error { code: INTERNAL_ERROR, frame: None, reason: "endpoint driver future was dropped" }))
 WARN 2021-11-14T16:31:08.419156Z [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\qp2p-0.27.2\src\connection.rs:L492]:
         ➤ Stopped listener for incoming bi-streams from 167.172.53.166:12000 due to error: TransportError(Error { code: INTERNAL_ERROR, frame: None, reason: "endpoint driver future was dropped" })
dont know if its any help but i got the following trying to add node
now node is timing out and waiting to retry after 3 min this is as far as my node got last night as well I never managed to get a node on line
but looks like up loading is working
Is the node connection info updated?
willie@leonov:~$ safe networks add community-test https://jc-com-net.s3.eu-west-2.amazonaws.com/node_connection_info.config
Network 'community-test' was added to the list. Connection information is located at 'https://jc-com-net.s3.eu-west-2.amazonaws.com/node_connection_info.config'
willie@leonov:~$ safe networks switch community-test
Switching to 'community-test' network...
Fetching 'community-test' network connection information from 'https://jc-com-net.s3.eu-west-2.amazonaws.com/node_connection_info.config' ...
Error:
   0: expected value at line 1 column 1
   /rustc/c8dfcfe046a7680554bf4eb612bad840e7631c4b/library/core/src/result.rs:1897
Backtrace omitted.
it was, but its down now though… it was not playing nice.
Never mind, keep at it. It really is appreciated.
Did you get logs?
not from this one no.
I have not grepped anything significant from last nights logs yet. Will keep looking.
Exactly what did you change for this last run?
ok, it looks better now. take 6 is trying to fly.
Trying the nodes built always-joinable is the only change.
and https://jc-com-net.s3.eu-west-2.amazonaws.com/node_connection_info.config is still valid?
Edit - what size are the nodes set to? Did you launch 17 of them again? I counted 17 seperate IPs for the logs last night. Trying to work out when we would fill thes nodes and require more if the always-joinable fails for some reason.
yes everything is updated, prob best to rm -rf $HOME/.safe though and start from fresh.
Gotta run brb, but it all looks good at my end.
5mb test file successfully put no got to make dinner unfortunately :frowning:
A treat for your ears
safe cat “safe://hyryyryynrghzy4uy7nhik9jr3yp9c69w59j6oi8xszmtrspjgac66jrb6ofyeuy?v=hbehx5bh8frkz4i1a4zmtobxa7y9nt66nyt1kf7ygwxohd1iajcfy”
ERROR 2021-11-14T17:27:24.016505Z [sn/src/routing/core/bootstrap/join.rs:L144]:
	 ➤ join {network_genesis_key=PublicKey(0ed7..751c) recipients=[Peer { name: 4aed11(01001010).., addr: 68.183.34.119:12000 }]}
	 ➤ Node cannot join the network since it is not externally reachable: 9n.nnn.nnn.nnn:36724
Unfortunately we are unable to establish a connection to your machine (9n.nnn.nnn.nnn:36724) either through a public IP address, or via IGD on your router. Please ensure that IGD is enabled on your router - if it is and you are still unable to add your node to the testnet, then skip adding a node for this testnet iteration. You can still use the testnet as a client, uploading and downloading content, etc. https://forum.autonomi.community/
My router is IGD compliant IIUC
same here trying again now
guessing something is up with the gateway
I am in the middle of putting up a free tier AWS instance for some other work - I’ll have a go at hijacking that for this test
I had 18 going at one point last night, right now I have 11.
Could easily add an additional external node now which I could not do last night so always-joinable is working.
size set to 500mb.
I am having a real hard time with Ubuntu versions though, the first 5 minute attempt earlier was on 20.4 and it was a little rough, changing to 21.4 has it running fine now.
What issues did you get with 20.04? I must admit to sticking to the LTS versions myself.
So 5.5Gb upload req’d before we need to add more nodes
belter im in with a manual port forward
when the node tried to boot strap i noted the port it was attempting to use and made a manual port forward before it timed out
my first node online in a long time one happy camper !
wife not so happy about the state of dinner though
node join was failing and get was too.
