Howdy Will, any luck tracking this down, at all?
Just wondering.
Just wondering.
I still canât replicate any issues
Everythingâs been working fine in all my tests, I have a tab open on my phone with it, working well for the past few months
Even when I update my balances it continues to work. I even have MaidSafeCoin listed in mine
Any information you can send me about your problem would really help
Okay, just opened a totally new session in a browser that hadnât open the page before.
Just added 1000 maid tokens:
$undefined right before the $0.00 popped in.
Next, I created a new name for a profile and again added 1000 maid tokens:
$undefined just for a split second, before the $0.00 showed up.
This is happening in several browsers in the same fashion.
Browsers tested: Edge, IE, Chrome, Brave, Opera, Firefox, Waterfox, and Vivaldi.
Thanks for that, am able to replicate now.
Looks like MaidSafeCoin is simply not working from Coinmarketcap APIs anymore, even when you try to type it into the custom fields it doesnât register any such token exists
Looks like they were pulling from Bittrex.
We might have to wait for them to fix things before that part of coinfolio works again. Or perhaps I can use a different website API.
Will look into that, thanks for breaking it down. And I guess MaidSafeCoin actually wasnât registering in mine, now that I look closer.
@SalvorinFex or anyone else using this,
for now you can feel free to add in MaidSafeCoin as a custom field and put $0.36 as the value and update it as you like.
Iâve been doing that for now in the meantime while I figure out whatâs happening with Coinmarketcap system
for a quick and dirty fix you could just pull maid/btc from polo with
[since i use python ofc python example
requests.get(âhttps://poloniex.com/public?command=returnTickerâ).json()[âBTC_MAIDâ]['lastâ]
and btc/usd from coindesk as
requests.get(âhttp://api.coindesk.com/v1/bpi/currentprice/EURO.jsonâ).json()[âbpiâ][âUSDâ]['rateâ]
or just use the value you already know anyway
their rest apis are pretty simple structured ⌠=)
thx, MAID is hard coded into the front anyway so we would have to go with something like this
