For ios there is cryptoholder. You have to enter and keep track of what you own by yourself. Then it will keep track of your value change over time since you installed it.
That’s Awesome Will, Thanks!!
@whiteoutmashups Hey Will, looks like MaidSafeCoins are missing now.
I have my amount in there but they aren’t in my total.
That is cool @whiteoutmashups and that is exactly what I need. Good work.
Can you send a screenshot?
Just refreshed and now it’s working…figures ![]()
Yeah your portfolio value all refreshes each time with the page reload, for current prices
Can the @moderators plz help me update the link in the OP, the current server for SAFE-FS Coinfolio is: http://165.227.55.168:8000
I changed the url. You couldn’t anymore?
thanks, that’s right, it stops you after a post has X age
Are you saving it with a username? And bookmarking your username?
Not really sure what can be going wrong. I’ve been using it stable myself for months, this way
Sometimes if you enter too many special characters into the custom coin field it can give problems. Working on that
The first screenshot is without a username.
The second screenshot is using one.
Just refreshed both tabs and they are still not showing MadidSafeCoin values.
EDIT: right after refreshing, before the value shows up it says, ‘$undefined’.
@whiteoutmashups
Just tried it also, in Firefox and Chrome same result.
Initially using Waterfox.
For now I’d try re-entering everything again.
And don’t add custom coins for now until you get the regular coins working
I’ll run more tests as well. Still trying to replicate your problem, as it’s running well for me
Maybe @moderators can help me update this one also, as it’s just as old.
Want to add:
EDIT: updated for mobile as well now ![]()
OKay, I might have found the issue, maidsafecoin is no longer in the list.
oh, because of the delisting?
ok I’ll check coinmarketcap apis again. Because I hardcoded maidsafecoin into the defaults, so if it’s delisted from cmkt in any meaningful way then that will break your results.
Will look into this, thanks, very helpful.
Although my MAID is showing successfully on the portfolio I have here. Will keep looking…
I’ve updated your old post as requested.
