RUST_LOG=sn_api,sn_node=debug I think
I have this running now
RUST_LOG=sn_api,sn_client=trace,sn_node=trace ~/projects/maidsafe/sn_launch_tool-0.0.3/target/release/sn_launch_tool -yy -vv -i3 -n15
Launching with node executable from: /home/willie/.safe/node/sn_node
Network size: 15 nodes
Launching genesis node (#1)...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--first", "--root-dir", "./nodes/sn-node-genesis", "--log-dir", "./nodes/sn-node-genesis"] ...
Genesis node contact info: ["0.0.0.0:12000"]
Launching node #2...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-2", "--log-dir", "./nodes/sn-node-2"] ...
Launching node #3...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-3", "--log-dir", "./nodes/sn-node-3"] ...
Launching node #4...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-4", "--log-dir", "./nodes/sn-node-4"] ...
Launching node #5...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-5", "--log-dir", "./nodes/sn-node-5"] ...
Launching node #6...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-6", "--log-dir", "./nodes/sn-node-6"] ...
Launching node #7...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-7", "--log-dir", "./nodes/sn-node-7"] ...
Launching node #8...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-8", "--log-dir", "./nodes/sn-node-8"] ...
Launching node #9...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-9", "--log-dir", "./nodes/sn-node-9"] ...
Launching node #10...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-10", "--log-dir", "./nodes/sn-node-10"] ...
Launching node #11...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-11", "--log-dir", "./nodes/sn-node-11"] ...
Launching node #12...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-12", "--log-dir", "./nodes/sn-node-12"] ...
Launching node #13...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-13", "--log-dir", "./nodes/sn-node-13"] ...
Launching node #14...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-14", "--log-dir", "./nodes/sn-node-14"] ...
Launching node #15...
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--hard-coded-contacts", "[\"0.0.0.0:12000\"]", "--root-dir", "./nodes/sn-node-15", "--log-dir", "./nodes/sn-node-15"] ...
Done!
But with an --ip flag it craps out
willie@gagarin:~/.safe/nodes/sn-node-genesis$ RUST_LOG=sn_api,sn_client=trace,sn_node=trace ~/projects/maidsafe/sn_launch_tool-0.0.3/target/release/sn_launch_tool --ip 185.218.13.176 -yy -vv -i3 -n15
Running '/home/willie/.safe/node/sn_node' with args ["-vvvv", "--ip", "185.218.13.176", "--first", "--root-dir", "./nodes/sn-node-genesis", "--log-dir", "./nodes/sn-node-genesis"] ...
