Buying Maidsafe tokens using bitcoin
I have bitcoins so where do I use them to buy Maidsafe tokens and can I save them in my bitcoin paper wallet…thanks for any advice.
hi,
you can buy MAID on poloniex, hitBTC, cryptopia, openledger.
[later edit]
check this post, here you can fins some info on wallets Omnicore wallet - the most secure wallet for your Maidsafecoins
(but keep in mind that hitbtc charges more than 200 maid for withdrawal of maid… At least it was like that last time I was told any numbers…)
Side note - Changelly seems to be an option too
I came across Changelly in my searches and purchased a small amount without too much trouble to see how things turned out. I used an Omniwallet to do the transaction by moving bitcoins to Omniwallet from Coinbase. Could I just have sent the bitcoins from Coinbase for this transaction? Also,can I send my Maidsafe tokens to a Paper wallet I’ve created to keep them in a safer environment?
There is also, this topic:
Which has some great comments about other options.
Hello.
I’ll just pop this link down here as an aide-mémoire and close off the topic:
Buy MaidSafeCoin
David.
